Question about Compaq ProLiant ML530 Server
Fan problem, wont boot
I've got an old ML530 that thinks the fans have gone. fans 1 & 3 are working, with green lights on. there are 2 empty bays, but the case says three are 6 in all.. cannot find them !!! i need to get to the C drive, but it keeps looping and saying "fans not working" can i skip the warning to get the server up and running......
    Problem Solver:
  • 6 Answers
Hi david yes there are six fans which are in use of Hot-Plug System Fans,System Fan,CPU Fan, Hard Drive Fan,Hot-Plug Drive Fans check all fans properly replace by swapping to each other if need more help go through this link:-http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01127466/c01127466.pdf it will help u,pls update ur server psp ,firmware and bios . thanks
Posted on Sep 06, 2007
SOURCE:
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
Mitsubishi WD 62725 - Message indicating impending lamp failure, followed by lamp failure. Replaced lamp and noticed a flashing green light. Pressed reset button and also disconnected for 12 hours. Upon...
Hi James,
First of all thank you for posting your question here at Fixya.
Flashing of the LED light green has two error code.
1. Lamp Fan failure - if the lamp LED at the front panel blinks green, this is an indication that there's a malfunction on the lamp fan. You've mentioned that you've replaced the lamp, please make sure that the connector of the fan and other connectors are securely connected. Double check it.
2. DM boot failure - If the Timer/Power at the front panel blinks green for more than 1 minute, this is an indication that the DM failed to booted up. I have a link where you can buy DM repair kit, click it HERE, it includes parts that are know to be faulty, illustrated instruction that will guide you in the whole process of repair. Your unit is a V26 chassis, when you are on the link, you can see two version of the DM repair kit for V26 chassis, one is the same working voltage of the capacitors and the other one is the upgraded version. It's up to you if you are going for upgrade or not.
Please let me know if you need further assistance.
Have a great holiday!
Kind Regards,
Mjsazon
Dec 23, 2011 | Televison & Video
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Nov 03, 2008 | HP Compaq ProLiant ML530 Server
Laptop does not power on !
first of all change ac cord and batter then try with the fan
May 16, 2008 | Acer Aspire 3004WLCi Notebook
Removing cd rom
Preparation Steps before removing CDROM:
1.Power down and remove power to the system.
2.Remove access panel.
3.Remove CPU fans and fan basket.
4.Pull the system tray out until it stops.
To remove the CD-ROM drive:
1.Disconnect the power and signal cables from the CD-ROM drive.
2.Loosen the thumbscrew located in the fan basket area to release the metal locking bracket.
3.Slide the metal locking bracket away from the center of the server.
4.Push the CD-ROM drive out of the front of the chassis from the interior of the system.
5.Pull the CD-ROM out and away from the chassis.
Apr 12, 2008 | HP Compaq ProLiant ML530 Server
ML530 Startup
Check your Hardware configuration.  This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not.  So it stops and asks you what to do next.
Hope that helps.
Eddyfix
Oct 12, 2007 | HP Compaq ProLiant ML530 Server
Open Questions:
See all Compaq ProLiant ML530 Server Questions
Compaq ProLiant ML530 Server Logo
218 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
