Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Six beeps of the standby light...
When my TV is turned on it works fine. Once it is off and you turn it back on it 'poofs' then the picture card thing lights up. After that the TV sighs and the standby light beeps six times - over and over. I unplug the TV to reset it. If I leave it for days - it may turn back on again. I think it may have something to do with humidity but not sure. Anyway - anyone know what six beeps means? How about any of the beeps?
    New Friend:
  • 76 Answers
Yes your suggestion is correct. This type of problem occurs due to humidity also. Solution is if your a technical person or service person just remove main pcb from the tv and blow all dust and clean it. Check whether the dry soldered in power supply area and jungle ic area. if found clear it. Now the tv is working well and good. 6 times blinking means problem in jungle ic area.
Posted on Aug 24, 2007
Possible Lamp Sensor Problem
Google the model number for six blinks for that is an error code---this set uses no lamp---it has 3 picture tubes
Mar 11, 2012 | Sony KP-65WS510 65" Rear Projection...
No picture on tv .
Please try the following steps :-
Turn your PS3 off into standby mode (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep.
Wait for the PS3 display to reset.
Hope this helps
Oct 27, 2010 | Sony Playstation 3 (PS3) Console
The playstation is comin on but i cant gat a picture on the tv why tried on different tv worked fine last nite
Ok, follow these simple steps and your PS3 should display properly on the TV.
Step 1. Turn your PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it then beep again 5 seconds later. Release the power button
Step 3. Wait for the PS3 to restart.
This resets your video resolution back to standard definition. You should now be able to setup your video settings correctly using the PS3.
Hope this helps and thank you for using FixYa
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
When i turn it on, the green light shows, but i don't have picture, sound, and the fan turns on at first, but then it turns off in a couple of seconds.
does the red light flash when it cuts off? if so this is the"yellow light of death" there are videos on youtube on how to fix this....youll need to have some electronics skills....
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power Button Light Flashes six times Chassis# PTV915
Replace SSB p#313912725871. (Small signal board.) New part #PH3912725871. They also sell a kit PH3912725871-KIT.
Oct 07, 2008 | Philips 50P8341 50" Rear Projection...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
