Just replaced yesterday and now we are getting the error code at the controls. Air won't work but fan & furnace will come on.
16. SYSTEM RESET
a. Turn the ON/OFF switch to OFF position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to ON.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
That's one of the problems. In all the paperwork that came with this RV, there is no manual that I can check to trouble shoot, no legend .... I tried looking online for the manual with no result. The digital thermostat reads out an E4, error. That's it
Thank you for the info. The stat did reset .......... Amen to ya'll
Ok have you tried to remove the cover on the top section? Are the controls on this on the unit on the ceiling/ Or on the wall with a thermostat looking control?
We have to have your error codes to help look at the trouble area. And although you say your getting one we need to know what it is.
A legend is sometimes next to a wire diagram in the wire terminal panel.
Look there and post back.
I just had the E4 code popup on my camper AC so I disconnected shore power and the battery for a few minutes and it fixed it and now works fine
