Question about Toshiba e-Studio 350 Copier
Toshiba e-studio 35 Copier Problem
Have a problem with Toshiba e-studio 35. It works great, But it does not completely turn off when main power switch is turned off. When main power switch is turned off, power light and panel display go off. But still working other parts In other words, it has a noise and getting hot inside of machine even though main power switch is turned off. It has same noise as it turn on. It has no noise and completely turns off if I disconnect Power plug and connect power plug again.
  • 24 Answers
There is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Posted on Aug 31, 2007
SOURCE:
I have a Toshiba e-studio 35 that has an error -c450.
turn power off
press 0 + 8 with turning the power on
write 400 then start
write 0 then Enter on the touch pad
restart the machine >>
else >>
Check if the edge thermistor is in contact with the surface of the fuser roller properly
Nov 04, 2016 | Toshiba Office Equipment & Supplies
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
Ny coppire E studio 280 & problem service ,c400
It is a problem with the fuser called as the oven
Turn the power switch off
switch on by pressing both buttons "0" and "8"
enter "400" and press "enter"
enter "0" and press "enter"
turn off the copier and then on again
Guillaume specialist TOSHIBA
Join me at +225 57 03 73 60
Jul 30, 2013 | Toshiba E-studio 280, E-studio 280
Toshiba e-studio 35 erreur code 303232
That's not your error code, that's your meter.
Feb 02, 2013 | Toshiba e-Studio 35 Copier
I have a toshiba studio 35 copier that displayes call for service, how do i reset it?
Press CLEAR+8 to check the error message.
If Cxx, perform 08-400, reset any value to "0"...
Feb 20, 2012 | Toshiba e-Studio 35 Copier
How can I get a meter reading for an e-studio 160 copier?
In order to get a meter count, turn the machine completely off (including main power,) and press and hold "0" and "8" simultaneously, then power on the machine. After about 5-8 seconds of holding these keys, the machine will boot into test/service mode, and at that point you want to type "257" and "start," then the meter count will be displayed.
-David.
Nov 03, 2010 | Toshiba e-Studio 205 Copier
Toshiba copier service mode.
Only a technician can decipher the Call for Service error.
Jun 18, 2010 | Toshiba e-Studio 35 Copier
Hi, firstly, I want to thank you for responding to
You could have an issue with your tray lift gear box. Most likely the motor has weakened or failed completely. This is located in the back of the machine on the bottom. If the motor is completely shot you will likely have to get it replaced.
May 17, 2010 | Toshiba e-Studio 35 Copier
We bought a used Toshiba studio 35. The
Hi:
With the copier turned off hold down the 0 and 8 keys together while turning the copier on . Continue holding both those keys down until a function screen comes up. At this point key in 629 and press the Start key. Then press the 7 key and press set. This will disable the Dept code functions. Shut off the machine and power back up.
Good Luck
Andrew
Jun 29, 2009 | Toshiba Office Equipment & Supplies
Toshiba E Studio 35 copier goes to power save
Hi:
Hold down the 0 and 8 keys while turning on the copier. Keep on holding down the keys until the screen shows a adjustment mode screen. Once it does this key in 205 then you should see a numeric value. Input 15 and press start to lock it in This will change you power saver mode to 60 minutes. Next enter code 206. Key in 19 and press start. This will change your sleep mode to 240 minutes. These are the setting that are most generally used when these copiers are initially set up. Then just turn the copier off and back on. I hope this resolves your problem.
Good Luck
Andrew
Mar 13, 2009 | Toshiba e-Studio 35 Copier
Toshiba e-Studio 350 Copier Logo
355 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
