Question about Samsung Televison & Video
Wont power on
When the tv is plugged in it makes a really high pitch whistle noise, don't know if the power supply is dead. I think it might have been zapped in the last big lightning storm.
  • Samsung Master
  • 933 Answers
You could have bad power supply capacitors, what is the TV model #
Posted on Jul 05, 2013
SOURCE:
gilheero
  • 207 Answers
SOURCE: High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Posted on Feb 05, 2008
SOURCE: High pitching sound
buy a new tv
Posted on Jul 26, 2008
  • 192 Answers
SOURCE: High pitch noise coming from the tv.
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Apr 26, 2009
damromeo
  • 16 Answers
SOURCE: high pitched whistling noise coming from tv after
you probably have a bad capacitor on one of the boards inside.
Posted on Mar 20, 2010
Testimonial: "Thanks. Is that an expensive fix?"
ginko
  • 19396 Answers
SOURCE: TV won't come on, it just stays in standby mode
Hi.
The TV staying in standby and the light flashing indicates that the TV is in fault mode (often called protect mode). This happens when an internal fault is detected, and the main board set the unit in forced stand-by with the led color changing.
Before doing anything else try disconnecting TV from power for ten minutes. Restart the TV with no device connected, leave it on for a while and see how it goes. Test the TV with different devices (eg. DVD, VHS,sat box, console etc .)
In your case it looks like there is no clear indication toward a particular fault. The TV coming on at random times, may point at a defective PSU, but other failures such as defective main board, overheating, defective inverter, or faulty Timing controller (TCon) may result in the same problem.
The most common fault that may cause the symptom you described is PSU. Unless there is clear sign that the PSU is damaged, this is still far from being enough to decide that PSU is the culprit. The power supply must be tested before replacing parts. Testing is done reading PSU out on different voltages. This is an operation that must be done by a trained repairer.
The high pitched noise may be given by a defective PSU capacitor. In that case the bulged or leaking capacitor is usually easy to spot looking directly at the PSU.
To book a repair call the manufacturer at the number listed on the owners manual.
To get part price, enter model here: ShopJimmy.
Regards.
Ginko.
Posted on Feb 19, 2011
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
When i turn on my 42 inch hitachi pd9700 tv it makes a fizzing noise from the back.after 10 mins it gets louder until its like a high pitched whistle.then when i try to turn it off by the remote the...
This problems it the cause by the power supply board.Those transformers on the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 17, 2010 | Hitachi 42PD9700 42 in. Plasma Television
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
Hi, I have a Magnavox 17MD255V/17 combo dvd-tv. Everything works fine except that the AC adaptor has a high-pitched whistle that continues while the tv is on. I tried unplugging from the the tv itself and...
TAKE THE AC ADAPTER APART. LOOK AT WHERE THE MANUFACTURER PUT HIS GLUE AND REDO IT CLEAR NIAL POLISH WORKS BETTER IT FLOWS UNDER THE PARTS BETTER. YOU CAN PLUG IT ALL IN WHEN ITS APART BUT MAKE SURE NOTHING CAN SHORT OUT. THIS WAY YOU CAN PINPOINT WHERE THE NOISE IS COMING FROM. OTHERWISE GLUE THE TRANSFORMER AND ANY SMALL FERRITE BEADS THESE SWITCHED MODE POWER SUPPLIES OPERATE AT HIGH FREQUENCIES AND LOOS PARTS CAN VIBRATE CAUSING THIS NOISE.
Dec 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Televison & Video Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
