Question about LCDDigital LCD7 Television
LCD Monitor Need to replace the monitor in TriwentPuran
  • 3 Answers
It's much cheaper to go ahead and replace the whole set because the T.V.s are so cheap that they cost less than the repairs.
Posted on Aug 23, 2007
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
My monitor fell on the floor and now my color is off. the color is darker on the left of the screen. Do I need a new monitor now?
I suggest you to buy a new monitor because it will be expensive to replace the LCD. You monitor LCD is damage that is reason why there is a dark color on the left screen.
To avoid any harmful accident in the future. Because it will create electrical spark inside the monitor which will be burn out the entire monitor or maybe result to smoke. There is no remedy in that particular trouble but to replace the entire LCD. But this is not advisable because it will cause you expensive cost of repair.
You need to buy new monitor and I suggest if you buy new monitor. Buy LED monitor which is better than LCD. LED monitor is a green campaign of every manufacturer due to energy saving specification and have a better graphics than LCD...
Hope this will help you a lot. If you any other question please don't hesitate to contact me
Sep 16, 2011 | eMachines E211H Monitor
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
Lcd monitor has streaks like herringbones
Dear i can send an information of your monitor problem please follow the instructions and make your monitor is right.
I suspect that there is a defect in the LCD panel.
Unplug it from the computer and see if they go away.
Try the monitor on a different computer and/or try a different monitor on your computer.
If the problem follows the monitor, then you need a new one. If it is under warranty get it replaced.
If it follows the computer then you may need a new graphics card.
Thanks.
AMAN,
Mar 24, 2010 | Dell 2000FP 20.1" LCD Monitor
My son crack the LCD glass on his 204T SyncMaster
The glass of the panel is glued or welded to the LCD wafer below, it cannot be replaced separately. Since the panel is the most expensive part of an LCD monitor, its probably the cheapest option to just get a new monitor - spare part ordering and extensive manual work required for the change simply outweighs the remaining value of the monitor.
Feb 09, 2010 | Samsung SyncMaster 204t 20.1" Flat Panel...
Does old mother board supports LCD monitor?
You’ll be fine.
Most LCD monitors either have VGA connection you’ll need or have VGA plus other connections but, all you need is the VGA connection.
Mar 01, 2009 | ASUS LCD Monitor
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
Gateway flat LCD dead
I'm not sure if your referring to the lcd monitor (gateway brand) or a laptop's lcd screen not working anymore.
1. if it's an lcd monitor...
a. test monitor in a different pc before assuming the problem is the lcd screen
b. replace the monitor if after testing monitor is in deed the item failing.
2. if it's the lcd screen from your gateway laptop.
a. you may be able to attach a regular analog monitor to the paralel port on your gateway.. test and see if the monitor that you attach will give you a picture (you may have to toggle with some some keys on your laptop keyboard to make have the signal going to the "externa" or attached monitor.
if the other monitor does not work either.. you video controller on your motherboard on your laptop may be failing and you may not have other options that to replace your laptop.
b. if the external/attached monitor works.. very likely the problem is the lcd screen for that you need to get a replacement and you may have to contact gateway to find out about pricing (or places to send your laptop for service if you're still within warranty). if you have an old laptop you may have to considere simply replacing the unit as buying a new lcd screen may very likely be more expensive than the same working laptop.
Oct 02, 2008 | Computers & Internet
LCDDigital LCD7 Television Logo
Top LCDDigital Televison & Video Experts
Are you a LCDDigital Televison and Video Expert? Answer questions, earn points and help others
