Question about Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive
Non detectable external self powered 40 GB USB Portable Hard Disk
I have an external TrekStor 40GB self powered USB portable hard disk. The problem is that it appears as if it is not detected by the computer after plugging it in. I cannot see it under my computer. So what could be the problem and solution.
  • 4 Answers
Id recommend trying these following steps: Go to: Start - Control panel - Administrative tools - Computer management - Disk management. Here you should be able to see the 40GB hard drive. Depending on your situation you may need to create a partition, to do so right click the unallocated space and choose to create a partition. The default settings will be fine. Good luck!
Posted on Aug 23, 2007
Its is blingking red ang blue and say driver not recogniced
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 10, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
My portable hard disk is not detecting by my PC/Laptop. it's working on other PC/Laptop. and i also installed my hard disk also giving beep sounds.
The power supplied by the pc laptop on the USB is insufficient to run the hard drive.
If you have an external power supply option on the hard drive, please use that.
Sep 06, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Can i make my portable hard drive an external hard drive?
It is already. Just connect it to a USB port and it should pop up as a new drive.
Jun 02, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Toshiba 120 GB USB 2.0
check if you have another drive which has the same alphabet as your external drive, if so then go to disk management and change the name of the disk.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Formated hard disk
Go to Computer Management
Then click Disk Management
You Will find Your Portable HDD without Drive Letter
Just Right Click and Assign a Drive Letter...
Thats all...
Jan 29, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
40GB portable Hard disk !!!
try go to hardware management. there you check if your harddisk is deactivated or if there is a problem.
please contact me if it doesn't work.
Jun 01, 2008 | SimpleTech Computers & Internet
Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive Logo
166 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
