Your can try changing the channel of the wireless signal by accessing your 2wire Homeportal's interface. try changing it using these recommended channels: 1,5,9 and 11. The channel is usually defaulted to 6 which most of the time conflicts with other high frequency devices.Hope this helps. If you are unsure on how to access your Homeportal's interface you just need to know the default gateway of your device. just go to start>run>type cmd>click on ok>then on the blinking cursor just type ipconfig/all and the number's beside the default gateway is the address of your 2WIRE Homeportal.Just simply open a browser afterwards and access those numbers you found on the cmd prompt. and it should show you the interface of the 2WIRE device.
Why does my 2wire modem restarts by it self? Some times the Internet light turns red while...
(More)
Why does my 2wire modem restarts by it self? Some times the Internet light turns red while everything else is green. And some times the wireless light turns on when I'm not using anything that uses wireless.
I have a 2wire home network. Can I use the HPNA connectors somehow to connect my DirecTV box to the...
(More)
I have a 2wire home network. Can I use the HPNA connectors somehow to connect my DirecTV box to the network?
