Question about HP iPAQ hw6515 Pocket PC
Replace Screen on HP6515
I have a cracked screen on my Ipaq 6515 with a second unit that has issues but a working screen. Does anybody have a manual or procedure to open these beasties up so I can swap the screens between devices. TIA Josh
Ok, to disassemble - remove four screws on back (#7 torx required). Then remove battery cover, battery, and SIMM card. Next peel the (on mine lower left portion of the) Warranty Void if removed sticker, and using a tiny phillips head screw driver, remove the screw revealed. Next, slide a thumbnail or plastic flatbldae screw drriver around the seam on the sides of the unit, to release the two pressure tabs on the sides and top. Then pull the top away, eventually freeing the bottom. Now, there is a system board exposed. There are three screws (tiny phillips again) two on the bottom and one at the top that can be removed, allowing the system board to be removed. Note that there are two ribbon connectors on one side - I didn't remove these. There's also a small plastic connection I did remove, then the system board will remove to the side allowing access to the back of the screen and keyboard assemblies.
Posted on Jan 20, 2008
SOURCE:
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq hw6500 wont turn on
If the battery was inserted to the unit prior to its storage, it might be the cause. Try charging battery directly in its cradle overnight or use new battery pack. If not then its hardware and/or formware problem. Sometimes electronic gadgets fail to work after prolonged storage due to to capacitor/condenser in its circuitry.
Mar 27, 2008 | HP iPAQ hw6500 Pocket PC
IPAQ 6515
problem with display so contact service centre for support good luck
Sep 04, 2007 | HP iPAQ hw6515 Pocket PC
Turn it on
Here is the page to download a user manual: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179111&taskId=101&prodTypeId=215348&prodSeriesId=501209#0 The screen you speak of is an initial setup screen, if you use the stylus and tap on the screen where the cross is. this will get you started using the device.
Aug 04, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 gps issues
Hello, You may need to go get the update to 5.21 .. heres the link .. http://www.tomtom.com/support/category.php?ID=3&Language=4&FID=3370 Install it and that will help Bob
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
Screen size
Post a list of program types you may be interested in and I may be able to suggest programs that support the 6515 !!square!! display.
Sep 11, 2005 | HP iPAQ hw6515 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
79 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
