Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony tv screen format changes when channels are changed
I have sony kdl4000w 52in lcd tv which when i change channels from my
digi box the screen format changes. ie when wide screen is selected it automatically changes to 16:9 format when channels are changed.
How can i stop this happening any suggestions please email. many thanks.
SOURCE:
  • 8 Answers
SOURCE: no picture or menu
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
Posted on May 04, 2007
Arpi
  • 326 Answers
SOURCE: Sony 61" lcd has bluish spots in screen, any ideas?
Hello, inside the set there is an optical unit with 3LCD panels. Somehow the dust particles came into your set and now the dust is all over the optical unit and 3LCD panels. Only way to solve this issue is to clean the dust. Please contact your Sony dealer. Best regards, Arpi
Posted on Jul 11, 2007
Mike258
  • 1498 Answers
SOURCE: PC input to Sony Bravia - from Sony Vaio Laptop - unsupported sig
Hi Julie,
There are a couple ways to go here. I'll give you the procedures step by step. If you want clarification on anything, just ask. If I make an assumption that is wrong, stop me and let me know. The more you know, the easier this will be for both of us.
First I'd like to double check on MisterSony's diagnosis. Refresh rates that are too high end up as a black screen on many LCD models.
This is my first assumption, the display settings are currently for both monitors. Your original screen is still functioning.
If so,
  • Right click on your desktop
  • Click Properties
  • Click the Settings Tab
  • Click the Advanced button
  • Click the Adapter Tab
  • On the lower part of that tab, there should be Refresh Rate. If it is not at 60 Hz, try to change it to 60 Hz.
  • Click OK
  • Click Apply
  • A pop up may appear asking if you want to keep the changes. Accept the changes.
Get back to me with the results. If it was already set at 60Hz. We go to the next step.
Mike
Posted on Nov 16, 2008
futureloginn
  • 734 Answers
SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Nov 17, 2008
SOURCE: can't get picture in wide format on the menu. 16:9 and 4:3 only.
I had the same problem with a 50". The only way I could fix it was to set my Bose system to 4:3 format and the tv to 16:9. Now you can use the zoom to get the right size
good luck
eltjo
Posted on Jan 19, 2009
Picture does not fill screen
You will need to change the screen format which would be in the settings option.
Jun 06, 2012 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
Tip
No Digital Channels can be picked up or slow to change channels by remote.
If you experiance a problem with changing channels on remote control of all digital channels, but the analog working ok.The problem is with the Digi Pcb. This is a stand alone pcb with the Digi tuner mounted on it.All Nec LCD Flat Panel Tv's From NL-T26HD1 TO NL-T46HD1 using module MDM- 300.
A quick repair is to replace the Digi Pcb at a Silly cost of $ 250, + labour cost and you will not get this repair.
Better than loosing a repair to so many cheap Imports is Replace the ( 27.000MHZ )Crystal on the Digi Board the one and only Crystal on this PCB and you have a repair and the set is back working as good as the day it was bought.
Good Luck Guys Lets prove to some that thought we tec"s were history.
on Dec 18, 2011 | NEC Televison & Video
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 40" tv wont stay on wide screen changes when channel is changed
Hi, there should be a setting for auto format in the menu. make sure that is turned off.
Aug 04, 2009 | Proview PA40JK1A 40 in. LCD Television
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
RCA TV/VCR combo T13060GY won't go below channel 5
I had a similar trouble with a couple of tv sets, one was a Granada and the other a Sony, but once connected to the satellite or digi-box via the scart socket it seemed to concentrate it's mind and override all the channels - so the tv stops being a tv set but becomes a monitor displaying whatever analogue video signal the digi-box sends to it.
The channels should arrive from the satellite receiver/decoder box and that remote control is all you need and the only thing you need to touch the monitor tv for will be the volume...
Scart sockets and plugs are apt to become dirty and unreliable and are responsible for many problems, including once a blue screen.
May 28, 2017 | RCA T13060GY Combo
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Air Digital No signal on the screen. Cannot change channels
hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Dec 26, 2008 | Mintek DTV-263 26 in. LCD Television
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Trutech 35" LCD connecting to cable box
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores. So many companies make their products. This website isn't the official site for all Trutech products,just some of them, like this 15" LCD TV.
Aug 15, 2007 | TruTech PLV1615T 15 in. LCD Television
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
163 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
