Remington MPT-3000 Logo
Anonymous Posted on Jun 25, 2013
To get puk code and a new pin code for my phone 09420253385
I locked my SIM card today.And when I tried to unlock SIM card, it said to type puk code and a new pin code.Although I typed password which I used to lock my SIM card,it was not successful.Help me to get and type puk code and a new code for my phone 09420253385.
Khant Thit
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2014
Khant Thit
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
136
Points
What is mpt number to request
puk code ?
Forgot my sim pin
If your phone uses a SIM card to operate, you can activate a security feature called a SIM PIN. The SIM PIN protects your SIM card from unauthorized use, and must be entered in order to use your phone. Enter it incorrectly three times and your SIM card becomes locked. You can unlock your SIM card on your own, however, by typing in a PIN unlock key. Your carrier can provide you with the unique PUK code for your device.
1 Contact your wireless carrier by calling the toll-free customer service number. (Find this on your provider's website or a recent invoice.) You will need to verify your account password before the PUK code is released to you.
2 Power your phone on. You will see a "SIM Locked" or "Enter PUK" message. Type in the eight-digit PUK code and press "OK."
3 Type in a new four- to eight-digit PIN code when prompted, then press "OK."
4 Verify your new PIN code by re-entering it when prompted. Press "OK." Your SIM is now unlocked.
Sep 11, 2018 • Cell Phones
I need the puk code and new pin number i tried puttin a lock on my phone and i didnt know the code to change it because it was a used phone and now im locked out of my phone because now i need the puk code...
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Sims locked
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Subject: How to unlock a SIM card
Customer's exact description: sims locked
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions on the entire battery of solutions.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
1helpful
2answers
These are my numbers 0796086761 and i need mt PUK please
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Solution: Provide instructions for unlocking a SIM card
PUK Codes
OR
? Log in to myAT&T.
Second Solution:
The Final Solution:
Change SIM Card PIN
*# 06 #
Ben
*# 06 #
Ben
Sep 11, 2011 • Cell Phones
1helpful
Need the PUK number for my nokia C3. tried to change my password and now i am locked out of my phone..
As you evaluate my advise.solutions and suggestions, there are a few things you must keep in mind:
• I did not diagnose your problem and am therefore only able to evaluate what you tell me. For example, if you ask me a fuse location, that doesn't mean that I can tell you the reason why the fuse blew. Keep in mind that I'm limited in my analysis to what you tell me.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices.
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated. If that happens, you might want to view me as being incompetent. However, I'm totally guided by the information that you provide.
Customer's exact description: need the PUK number for my nokia C3. tried to change my password and now i am locked out of my phone..
PUK Codes
OR
? Log in to myAT&T.
Note:
Second Solution: You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Nokia Software Solution for Unlocking a SIM Card
There is also another piece of useful software that can be used on virtually any cell phone. Click on this link: Universal SIM Card Unlock Software
The Final Solution:
Change SIM Card PIN
*# 06 #
Ben
1helpful
I have bought an second hand e71 and whenever i put my globe simcard the phone shows simcard registration failed.i tried to buy a new simcard but its still the same.how would i fix the poblem?
Customer's exact description: I have bought an second hand e71 and whenever i put my globe simcard the phone shows simcard registration failed.i tried to buy a new simcard but its still the same.how would i fix the poblem?
Discussion: Problems of this type can be either Phone Locked, SIM card Locked, or Lost Password. Customer did not provide sufficient detail to narrow the problem.
Solution: Provide instructions on how to deal with all three possibilities.
PUK Codes
PUK Codes
OR
? Log in to myAT&T.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
Ben
http://download.cnet.com/Universal-Simlock-Remover/3000-2381_4-10380518.html?tag=mncol;2
2answers
Sony ericsson w302 lock sye sim card lock i dont no problem.
PUK Codes
? Log in to myAT&T.
You can also do it without any assistance from anyone, However, be sure to read the following carefully because there are pitfalls.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators. If you are interested in a software fix, click on the following link: Universal SIM Lock Remover
Change SIM Card PIN
*# 06 #
Ben
*# 06 #
Ben
How can I unlock the phone screen if I don't have the password?
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave'.for today.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices. Diagnostic tools can be borrowed from AutoZone for FREE:
Subject: How to unlock a cell phone
Customer's exact description:how can I unlock the phone screen if I don't have the password?
Discussion: Problems of this type can be either Locked SIM card Locked, or Lost Password. Customer did not provide sufficient detail to narrow the problem.
Solution: Provide instructions on how to deal with both possibilities.
PUK Codes
? Log in to myAT&T.
Change SIM Card PIN
*# 06 #
Ben
2helpful
Okay so i got a new phone and i was trying to set a security lock but it cam up with this puk code thing - that it wanted me to enter the Puk code. I went to optus and they gave and reset the puk code for...
call your provider, they can give you the right PUK code for your phone. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T or your provider to unlock your SIM card.
Aug 13, 2011 • Cell Phones
4helpful
2answers
What is puk code?
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your service provider to unlock your SIM card.
You can obtain your phone's PUK code from your local operator by calling customer care.
Hope that's help you...
Please don't forget to rate me OK for helping you...
Thanks....
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gene Lawson
Mike Cairns
Mike Cairns
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
