Question about Panasonic CT-30WX15 30" TV
No Picture/ No Sound.....Nothing
Has no function whatsoever, plug it in and it makes that common TV power on sound 3 times in a row and thats it....Nothing.
    Genius:
  • Panasonic Master
  • 1,691 Answers
Most likely, the power supply, and or one of the scan circuits are in failure.
You would have to have an experienced TV tech do some diagnostics to determine where the area of failure is.
Jerry G.
Posted on Apr 25, 2008
SOURCE:
A JVC LT42XM48 LCD Television set. Takes power has no picture or sound.
As a first step , if it is controlled via the remote, check that the remote batteries are good and that it is functioning ok. Does the tv show anything att all? If it does come on but shows nothing then it might be that the source selection is on the wrong kind of source, you can find on the remote whether this is so by going to the source menu which should probably be on digital. (I am assuming that you only have digital broadcasts where you are.
If there is no picture whatsoever ubplug the set and check whether the internal fuse(s) are ok.)
Jun 08, 2015 | JVC LT Televison & Video
Jvc no power when plugged in
you tube might have blown ouy that's a big problem.Next time make sure you plug your TV in a surcharge protector
Nov 12, 2012 | JVC LT-37X898 37 in. TV
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
The red light on front of tv is on but tv itself (picture), sound
Check all the picture bulbs works.
This is a plasma tv right?
U have it along time right?
Aug 13, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Old zenith intermittent power on problem
would need a model number and if it that old wouldn't advise in fixing it.
Oct 10, 2007 | RCA F27442 27" TV
Tv
Although you did not mention what the make, model number or type of TV it is, I will assume that you are using a cable or satellite box, and the most common reason for what you are seeing is the TV is on the wrong channel. Using the TV's remote, make sure the TV is on channel 3. Most of the time that is all you need to do.
Sep 06, 2007 | Televison & Video
WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Aug 28, 2007 | Televison & Video
Panasonic CT-30WX15 30" TV Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
