Question about LaCie (301015) 120 GB Hard Drive
Hard Drive does not show up on desktop
I have not used my external hard drive in awhile, but I went to go back up some work and when I plugged in the USB cord it did not show up, i tried different USB sockets and still nothing, I could hear the hard drive making noise, and also it would sometimes make a beeping sound...Also I have a mac...
  • 3 more comments
  • Karin Nicolas
    Karin Nicolas Jan 17, 2008
    Mine [Lacie Porsche 60Gb usb] shows the dialog "no readable disk" after a fall from table (not so hard) and it can be heard a beep (actually two alternating different tones if 'beep') when plugged-in. A lot of sensible data catched inside. Will thank any help or guidance.
  • newtimer Mar 14, 2008
    my 120 rugged drive seems to power up and the disk runs, but I get no icon on my desktop, nor disk in the disk utility application. How can I mount this drive?
  • erinargyle May 29, 2008
    My rugged LaCie (might be 200GB or 120, not sure) is doing the same thing on my PowerBook G4 and unplugging the USB cord doesn't seem to help.  I've tried it in both USB holes.  It showed up for a bit and I began the downloading and then the process stalled and seemed to stop for about 30 minutes so I restarted and now I can't get it to show up on the desktop again.
  • adschudmak Jul 31, 2008
    Same here!
    I have plugged in a 120GB Lacie rugged which I was using for a fair while with no problems.  But recently it just doesn't show up and I don't know how to open it!  It sounds/feels like it is spinning, and when I go to "about this mac" and "More info.." I can see it there in the Firewire section.
  • victordennis Nov 14, 2008
    Hard drive does not show up on computer
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Nov 05, 2009
I have the same problem once in a while too with my lacie rugged.. I'm lucky i also have a PC with windows on it and the program MacDrive. Windows XP with macdrive regonises it,.. and it allows me to backup the harddisk and reformat it.. I have not yet found a better sollutions
    President:
  • 317 Answers
If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. Or you can try leaving it plugged in while restarting to see if it is recognized. Does your computer recognize other things you plug into it? If not, plug and play might be disabled.
Posted on Aug 23, 2007
My Computer not showing my toshiba canvio hard drive
Have you tried shutting down the computer ... unplugging the hard drive ... re-starting the computer .... and plugging in the hard drive (after the system is all ready for use) ?
It's likely the hard drive was "ejected" ... (after defrag ? or when the system went into standby/hibernation) .... and hence you see the icon in the task bar ... indicating that you can safely unplug the hard drive from the computer.
Feb 18, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
I plugged my external hard drive into my usb port where it downloaded the driver perfectly and it said everything was working properly. Then i went to my computer and the hard drive does not show up for me...
above the control panel there is a computer word
click on that and it shows the external hard drive double click on the hard drive icon and that will open up all of the files and folders on the hard drive
Jan 05, 2018 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Frozen WD 250GB External Hard Drive
Can you try and access this external hard drive from another computer, if not, then try a system restore back to yesterday if possible.
Jul 24, 2009 | Western Digital Caviar WD2500BB 250 GB...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
I was trying to save a file from laptop to my USB external HD, Due to big files it went to a delay write failure, my external HD suddenly stopped working. Whenever I plug in to any computer it just detect...
Hello. It sounds like your external hard drive has crashed, or is getting ready to crash. If you can back up your data, you should do it now. If not, you should get your drive to a professional as soon as possible.
I'll monitor this thread. If you have any more questions, please feel free to ask.
Jason
Jan 26, 2009 | Computers & Internet
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
External hard drive not recognized
I have a WD3200 usb Hard drive. I am looking to partition it. The problem i encountered is when I go to the disk management, the drive shows up as disk one but below it , it says no media. its like the computer knows that there is an external storage device attatched but cannot access it. Also if I try to get into the disk from my computer, it says "insert disk"
Any suggestions?
-Oliver Fernandes
Sep 03, 2008 | Western Digital (WD3200JS) 320 GB Hard...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
LaCie (301015) 120 GB Hard Drive Logo
1,503 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
