Question about Sony Handycam DCR-TRV280 Digital Camcorder
Re insert tape
It tells me to re insert tape over and over what do i do to fix this problem
    Brigadier General:
  • 6,966 Answers
Hi, Don't be surprised with the solution others have found. Have a look at Good luck.
Posted on Aug 23, 2007
Why is the unit Magnavox vet/DVD recorder turning off when I insert the tape, and when power back on it ejects the tape.
There is something wrong with the mechanism, either the main drive mechanism, or the cassette holder part. Possible physical damage to the plastic parts. When the tape is inserted a device called a mode switch tells the electronics which position both mechanisms are in. If they go out of sequence, due to damage, or a faulty mode switch, the electronics shut the system down to prevent tape damage. When you power it up, the system thinks it is eject mode and chucks out the tape.
Apr 17, 2016 | Magnavox Televison & Video
Cannot load tape
No problem the camera is telling you to use tape head cleaner before trying to record more movies that all.
Jul 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Mini dv
mam try to check the tape if its correctly inserted to the camcorder. it must the tape itself or the tape compartment has the problem. insert the tape and see if its feed to the tape head and be sure that it will close with no problems. if the problem still occuring or persisting then try another dv tape and see if you got the same problem. otherwise go to the nearest repair shop to be able to fix with the use of their tools. hope that helps you ma'm!
thank you for using fixya
Dec 10, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Rec Inhibit Light remains ON
The easiest way I know to fix the problem is just play tapes. Sounds like a bad switch contacts. clean the contacts or replace the switch. I don't know of any shortcuts. Sorry
Apr 16, 2008 | Sony PVW-2800 VCR
Re insert cassette!
Reseat the battery and try tapping on the cam one or twice it should work, had the same problem
Dec 25, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony Handycam DCR-TRV280 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
