Question about Zenith B27A11Z 27" TV
Color red,green and blue is making a circle on the screen
I replaced a burned capacitor cx3211 and diodeDx3204 on this television two moths ago and it worked fine. It suddenly started to show colors in a circle in the middle of the screen. It seems like all the colors are there but are distorted. The picture is perfect. I will appreciate any help. Thank you.
  • 2 more comments
  • Fritz911 Aug 23, 2007
    Setting the color setting to 0 makes no difference....the colors stay there.
    Can you tell me what the resistor number is by any chance?
  • Fritz911 Aug 24, 2007
    Thank you. My e-mail is [email protected]
    Thank you, I found thermistor PTX3415 open circuit, replaced it and it works fine.
    Sergeant:
    Champion:
  • 326 Answers
Hello, please replace the PTC resistor. It is positioned at the primary side of mains converter. Best regards, Arpi
Posted on Aug 23, 2007
  • 1 more comment
  • Arpad Kothai
    Arpad Kothai Aug 23, 2007
    the purpose of PTC resistor is to make demagnetisation of picture tube.
    Best regards,
    Arpi
  • Arpad Kothai
    Arpad Kothai Aug 24, 2007
    please check the position for PTC resistor PTX3415, relay KX3401 and connector for degaus 3T8.
    I have prepaired the service manual for you. If you want it please leave your email I will forward the manual to you.
    Best regards,
    Arpi
  • Arpad Kothai
    the manual is sent by Pando.
    Best regards,
    Arpi
SOURCE:
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
46 toshiba plasma has red tint in back ground
If you can see the red tint with every input source and also in the On-Screen Menu, then this indicates that the Green phosphor is burning off of the screen faster than the Red and Blue. This is typical of plasma screens. Even if you dont watch a lot of golf or football, green is the most dominent color and burns out of the phosphur pits(pixels) faster than the Red and Blue. Take away green, you are left with Reddish looking screen and Pink whites. This is not repairable.
If the Menu looks nice and white, check your source cables.
Good luck
Dec 30, 2009 | Toshiba Televison & Video
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Screen is yellow tint regardless of color adjustments we make. there is a red circle when the screen is black
A discolored Blob or blotchy pattern usually in the center of the screen. the problem is becoming all too common with Hitachi projection sets. What happens is that one of the lenses in the optical block (or light engine) starts to burn (in thi scase the blue one) or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far-gone except to replace the light engine-at a cost that makes it not worth repair. if the damage is minimal than to reduce further damage, the air filter should be replaced. The Light engine needs to be removed in order to replace the air filter. Be sure to vote/rate me if this helped Thanks!
Oct 12, 2009 | Hitachi 60V500 60" Rear Projection...
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Screen Burn In ?
Nope Not unless you replace the tubes with the burn in them You have to take off ther front screen and look into the lens while tvs on and you will see what tube is burned worse. Sorry!!! but I have heard of folks equilizing the burned tubes by taking a solid color one at a time (red,green and blue) and keeping on only one color on for 4 to 6 hours one at a time and them all on at a time for a solid white and have seen some pretty good results.. Good Luck
Apr 19, 2006 | Zenith E44W46LCD 44" Rear Projection...
Zenith B27A11Z 27" TV Logo
120 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
