Question about Albatron LNX-21TIS-3 Television
Albatron LNX-21TIS-3 lcd tv does not power
I have a Albatron LNX-21TIS-3 lcd tv. It does not power at all. (bad power supply?) Cant find any local repair shop familiar with that brnd. Also the website http://www.albatronusa.com/ has email fax and (you have to look for it hard) phone number but fax is always busy, phone says line is disconnected and email does not get answered. help!!!
  • 4 more comments
  • soazeros Nov 05, 2007
    I was surfing around one night like I always do, when suddenly my display went blank. The power LED (usually red or green) is now shining yellow. There is no activity on the screen, unless i unplug the main power and plug it back in, there is a quick flash in the screen and yellow LED again. No buttons are responding or anything. Is there anything i can do?
  • Jloo Dec 11, 2007
    I have the same proble. I moved my TV from one place to another and now the screen is just blank.
  • Gigabitdrew Feb 19, 2008
    Mine has a dead power supply. I opened it up and took out the power supply, and it has a burned mark on the board. I can not find a replacement or anyone willing to work on it cheaper than I can buy a replacement.
  • JPK480 Feb 22, 2008
    I also have the LNX-21TIS-3 and I was using it as a TV set and a few months ago it just went blank on me. I then used it as a PC monitor after that and now it just did the same thing hooked up to my PC. I turn it on and the LED is green but the blue screen flashes on then off in like 1 second. Any idea why his is happening?
  • Anonymous Oct 06, 2008
    Hi here, I have the some problem. I am in Australia and I am unable to find either the part or someone who can get it fixed.....anyone who could give me a tip.....cheer
  • lwmusings Mar 05, 2009
    What power supply did you end up using? Trying to do the same things ourselves?
I just fixed my Albatron LNX-21TIS-3.
The power supply had gone out so I took an ATX computer power supply and changed the plug.
The Albatron runs on 12V and 5V just like the ATX computers. The trick is to find a power supply that is the same size then you just modify the wires on the power plugs to match up.
Posted on Apr 15, 2008
SOURCE:
Then i turn my rca tv on manually it wont come on
How old is the RCA TV. Is it an LCD Projection model or the older CRT (3 tubes - Green, Red and Blue) type projection model?
If LCD it could be a bad lamp or power supply. If a CRT it could be one of the Tubes is bad or again a bad power supply.
Nov 09, 2014 | Televison & Video
My tv lcd cant turn on
unplug wires from the power supply to the main board, if you still don't have 5V stand-by the power supply is bad. could be fuse, capacitors or anything in the 5V circuit.
Feb 18, 2014 | LG 42LC2D 42 in. LCD HDTV
Tv goes off cant get it to come on
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 07, 2012 | Element Electronics FLX3220F 32 in. LCD TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Tv wont turn on power button just keeps flashing and making a clicking noise but after 30 minutes it comes on
Your power supply needs repaired. You have some bad capacitors on it. I published a tutorial in my Tips & Tricks which can help you identify and replace these parts. Have a look if you want to try to fix this TV yourself. Best wishes, I hope this was helpful.
May 07, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have 2 View Sonic 32" LCD monitors that are used as televisions. One of the monitors randomly turns off, and takes a couple of attempts to power back up. The other recently just quite powering up,...
You may have power supply problem due to bad caps, open it up and look at the power supply module for bulging top or leaking. To have it repair will more likely to be over $100 plus parts if you can find the shop to repair them.
See what usually fails in monitors and TV: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Computers & Internet
I need a new power cord with the box and cant find anywhere, please help.
The TV needs 12vdc 5A switching power supply, http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=1952370
You still need to get the main input power cord for it which you can get from local PC repair shop. One thing about this TV is that the backlight inverter board goes bad on most set.
Jan 24, 2010 | Proscan 19LA25Q 19 in. LCD Television
USER /MANUAL/ NEEDED FOR ALBA LCDW16HDFP . NEEDED TO SET
I need to tune channels in Alba 15in flat screen tv, lost the manuals
Jan 18, 2010 | Albatron LNX-21TIS-3 Television
My Viewsonic N4060W 40" LCD TV will not come on, i get a steady green light when power button is pushed but the screen is blank and no sound. My TV is 3 years old and just last year i had a somewhat...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. If the tech installed a used power supply, it may be bad also. 3 years are typical for capacitors to go bad.
Nov 15, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
My digital lifestyles 42 widescreen lcd hdtv won t power on, When you hit the power on button the green light comes on but no picture or sound.
PLEASE NOTE IF YOU HAVE NO EXPERIENCE IN TV REPAIR SEEK OUT LOCAL TECHNITION OTHER WISE CHACK THESE THINGS BELOW.
1. check power supply
2. fuses
3. inverter.
Make sure you have no bad capcitors a bad capcitor is a leaking one or bulging at the top or sides if that is the case please replace them.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
372 people viewed this question
Top Albatron Televison & Video Experts
Ekse
Are you an Albatron Televison and Video Expert? Answer questions, earn points and help others
