You have the T103 timer rated 120-240. The clock motor part of timer is 120Volt. This is a very versatile timer, but confusing for non-electrician and electrician alike.
Solve problem by converting timer from T103 to the 240V T104 by changing clock motor from 120V WG1570 to 240V WG1573.
Buy wg1573 clock motor at WW Grainger or drillspot etc.
Resources:
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
This simple fix is intentionally designed by Intermatic so their timers are not only adaptable to all electrical needs, but also can be maintained to last 25 years by replacing clock motors and trippers as needed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
SOURCE: Changing Pool Timer
As long as you get a new timer that is 220/240v and is the same amperage or larger, you should be fine. Wiring would be the same.
SOURCE: Turned off main circuit breaker for maintenance
OK .. first check the breaker in the main electrical panel, make certain that it is retset, then the breakers in the pool disconnect, making sure they are reset and feeding power to the pump. Oh just so there is no confusion. when resetting a breaker, press firmly to off , then back to on .. if the timer will opperate the clock dial , then it should be good with turning on the pump.
SOURCE: hello i hooked up a t104 timer to a 220 pool pump
I assume it's an Intermatic T104. I believe this has a 230V motor, which is best for your application. Since you only have 2 hots and a ground I assume you're only switching one leg to the motor. That's why the timer won't run. It need 240V to run the motor. You need 5 wires. Two "hots" coming in, and two going out to the motor along with your equipment grounding conductior (green). This will disconnet all power to the pump when off. Pay attention that you put the two incoming leads on correct terminals which I believe is #1 and #3. That's because those terminals also power the clock. Then connect the motor to #2 and #4 which go to the motor. 1 closes to 2 and 3 closes to 4. The equipment grounding conductor connects to the GR terminal (Green)
The instructions are available from Intermatic if you click on the below link.
240 volts will have two 120 volt lines and a ground(green or bare) or neutral (white) wire.
If your system is 240 volts the Red and Black wires are hot should be individually connected, one to terminal 1 and the second color to terminal 3. The load or pump in your case should be connected to terminal 2 and 4. If you want to wire a switch to the load you need to decide on how you want the switch act, 1) as an auxiliary on 2) as an emergency off. If you want an auxiliary on for the pump, you need a DPDT (Double Pole Double Throw) 40amp switch (what should be in the house). Run the appreciate gage of wire (AWG 8 for 40A) from terminal 1 to one pole of the switch and a wire from terminal 3 to the second pole of your switch. Next run wires from the switch contacts from the two remaining switch terminals to terminals 2 and 4 on the timer matching the Red side on the switch to and Red on the timer and Black side on the switch to Black on the timer. The timer will control the function of the pump, and the switch will turn the pump on when the timer is off. If you only have two hot wires coming from the house attach them to terminal 2 and 4. If you want an emergency stop you need to wire a second DPDT 40amp switch and disconnect the load wires from terminal 2 and 4 and connect each one to the opposite poles of the switch. Using the correct gage of wire you need to connect a red and black wire to the two separate terminals of the switch. When the switch is off the pump will not work but the timer will keep the current time. The color of wires may not be the same in that situation you will need a multi meter to identify the wires.
I need a little more information on the pool sweep timer. Are you using the same timer or just the power? Is the power 120 or 240 volts? When do you want the pool sweep to be active?
no you don't need to get another one, you only use one of the hot wires coming into the timer for the clock motor call me if you need further help. 865-888-1220 if no answer try again no msg pls.
