Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Vista compatibility i am unable to connect my apple airport express to my network now that i am running vista premium. i had no problems with XP. does anyone know how to make it work with vista. thank you
  • JoannaP Dec 27, 2007
    Im running Windows vista and have just installed Airport Express. I've also encountered the problem that the Airport Setup Assistant doesn't install if you're running Vista. All I'm trying to do is connect my PC to my stereo via the airport. I've tried re-installing but still no luck. I've also run the install exe in XP SP2 compatability and the Admin exe in XP SP2 compatability. I've tried connecting through the admin exe entering 10.0.1.1 as the add and public as password but Im getting error -6753. I'm having to enter the IP add and password after clicking other as the re-scan isn't picking up the unit and hence I'm unable to access the Configure button.
  • fransvanb Mar 03, 2008
    same probl here.
    is there a solution for a non mac user?
I'd advise doing some research before I go out and throw down $$$ on a device that you know nothing about. Seems a bit negative, however it is common sense...
Posted on Aug 22, 2008
I had problems with the installation also on Vista. I used my work PC (XP) to connect and flash the latest firmware. After setting up the AEBS as a new network, I was able to see the Network but still unable to print. I used WPA and TKIP for the encryption and IP_Networkname.local.9100 to get my printer to work. Printer name was Networkname.local on port 9100. I had to download printer drivers for Vista from the manufacture as the advanced features were not available with the Windows supplied USB printer driver. The light blinks amber but printing works like a champ, even pauses in the middle of manual duplexing and prompts for the reload. I've used it with both XP and Vista and it really made my day since I no longer have to lug my laptopts to the other room to print.
It is not impossible to use this device with Vista as many post claim, but you might have a configuration challenge ahead of you without the latest firmware and printer drivers. I believe I ran the Airport Express and Bonjour utilities in XP SP2 compatibility mode.
Posted on Aug 04, 2008
I had the same problem, 1st uninstall itunes and the apple express software, do a regclean. 2nd place the cd in the drive but do not install yet. open the cd to the install.exe file right click for Properties and check "Run this program in compatibility mode for" Windows XP (servive Pack 2). Then install, after goto the program folder were the "Admin.exe" and do the same thing to run in XP mode. Then run "AirPort Admin Utility" on the bottom left hand corner you should see "Other" box enter the IP address and password. of the airport express, This works for me. Plus if you have a second pc with windows xp that will work as well network wireless as long as the apple express is wired to the router you can program it. I'm trying to do a WDS wireless network from my d-link 624 to two airports. I can get it to see the D_link 624 but I can't log to the wireless network and surf from other pc with xp wireless?
Posted on Oct 02, 2007
    Genius:
  • 1,139 Answers
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Posted on Sep 12, 2007
I have bought this horrid device which appeared pretty useful in the ads, unfortunately it did not work with Vista. I feel like suing apple for this, they should clearly mention in their promos that it is not vista compatible. Do hell with airport express and the Apple. Hate it.
Posted on Aug 12, 2008
Unable to Configure the Airport Express wireless using HP Pavillion running with Windows Vista
IN WINDOWS YOU CANT RUN MAC (APPLE) APP THIS FOR MAC SYSTEMS LIKE IPOD,IPHONE,MAC PC,ETC...
Mar 29, 2012 | Apple AirPort Express Base Station with...
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
Vista doesn't allow me to join a new network
Apple people don't know anything about how windows products work. You have to contact microsoft. There might be some conflictions with microsoft not being able to use that particular product. Vista also has a "Wonderful" new feature that makes it not be able to recognize any other computers on the internet unless they either have vista or download an update. This may have something to do with it.
Jun 11, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Just installed Airport Express. I can select it from iTunes on my PC running vista. The music plays but songs intermittently stop...it like it can;s download fast enough...suspect the laptop can't send...
Make sure that between the laptop and airport express you don't have devices that can interfere, like microwaves, phones, etc.
Also, if its a newer express try using the 5GHz band and that the airport is set up to "Join the network" not "Extend".
Dec 25, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple Airport Express not working
Throw the device out of the window, the apple folks are terrible and liers they mislead us into buying this device and it is not working with most Vistas.
Jul 28, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Wireless doesn't work!?
sure...since the Airport Express runs on DHCP, and your HP may or may not integrate with that standard, you most likely need to adjust your Network Settings for that connection, so your HP is compatible with the AE DHCP settings. Hmmm..let's see..who will be most helpful? www.apple.com no doubt..
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv9000z Notebook
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
2,125 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Peter Dragonetti
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
