My fuel pump normally makes a buzzing like sound. I had a feeling that it may stop functioning. A week ago whilst driving the engine just cut off, when trying to start her again I noticed that the fuel pump was not making the buzzing sound anymore. Could it be that the fuel pump needs to be replaced or is there fuses, etc that I can look at before purchasing a new one.
Yes the fuel pump is supposed to buzz and so if it has stopped buzzing then it is simply not working. There is a fuse and a relay for the pump, to check, you can also run a feed straight from the battery to the pump, this will tell you if the pump is dead or not.
If u could hear the much noise from the pump it was failing, so yes u will need a new fuel pump, but 1st check the fuel pressure to confirm this, they are not cheap.
