Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I am "locked out" and can;t add a Dell laptop.
I am locked out and can;t add a Dell laptop to the router. can;t find my security codes, etc, and even if I could I am not sure I could get the laptop going. I am seriously low-tech. Help!
  • trrcdc Aug 12, 2008
    can not use HP laptop with wireless
  • Anonymous Dec 30, 2008
    I have D-link router WBR-2310 , also purchase antena to enhance my ability to pick up in a den area, but still not able to connect to my dell laptop.
    Can pickup in every room except one.
    help
    Problem Solver:
  • 9 Answers
If everything works properly in all rooms but one, there must be something blocking the signal between the router and that particular room, or
if it the farthest away from the router that room could be at the end of it's signal. You could try just relocating the router to a more central point and sometimes just moving it a short distance can change the whole deal? Try it, what could it hurt?
Posted on Jan 22, 2009
    Brigadier General:
  • 6,966 Answers
Hi, The default IP for most D-Link routers is 192.168.0.1. Even if you're locked out, doing a hard reset to the D-Link AP/Router will put it back to default (but of course that would delete all settings including your security codes (which I presume you're referring to the WEP or WPA and/or MAC address filter)). This would grant you full access using the web configuration utility. Follow the instructions of your manual which is also available from the D-Link website or post again if you need specific step by step instruction. Some probable reasons you can not perform the above is if: 1. Your ISP has given you a very specific configuration and/or static IP add & you do not have the details; and/or 2. The AP/Router is physically not accessible to you; 3. There are other clients connected to the AP/Router that you can not re-configure if you do a reset; 4. You do not have administrator privileges to modify the AP/Router's configuration. Post back also with info on: How many wired or wireless clients connected to the AP/Router and what is their typical IP settings; Try to get your ISP/WAN settings; and availability of manual. Good luck and kind regards.
Posted on Aug 23, 2007
SOURCE:
I need to add a laptop to my router but cannot find the key code on my computer. can you tell me how to find it?
You computer's wireless card needs to be configures with the router's wireless settings ie. SSID, encryption key etc.
To configure your wireless card and to secure your wireless network from unauthorized accwss, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
Dell wireless router WRTA-108GD... How do I determine Security key # to activate on new laptop?,,,,, Thanks..Keith
You can secure your wireless network wit WEP or WAP code.
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
Thanks for using FixYa.
Mar 23, 2010 | Computers & Internet
How can i retreive the security code to add on to my new laptop?
The question is kind of odd.
RETRIEVE meaning you once had it?
Add like security to your lap top?
I think your asking for how to access a router with security?
Reset your router by pressing the reset button.
This will remove the security.
Connect to the router, access its menu, and add security again.
Mar 16, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Running Vista. My laptop won't conenct via wireless, but other laptops i add can connect via wireless to motorolla SBG900, even though i have added my laptop's mac address for the dell wireless card.
You need to ensure you laptop has DHCP set to OFF and disabled, START>>RUN>>services.msc enter, scroll down to DHCP, set to OFF and Disable.Reboot. Now check that the PC, it must have a login password, must be in same Workgroup, and have Sharing enabled, too. it also MUST have a Name too. The "Other" PC's all need to be the same, workgroup, password, name sharing etc.
Mar 14, 2010 | Arris SURFboard SBG900 Wireless Router...
I'm trying to connect to internet via wifi and it's asking for a device password. what is that? this is a d430 dell.
I suspect the device that is asking for a password will be your wireless router. Normally, the password, or key, is printed on a label on the side or bottom of the router.
Nov 21, 2009 | Dell Latitude D430 Notebook
Need to add a dell laptop to a wirelees router how do i get the network key to allowed access
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Nov 17, 2009 | Dell Latitude D610 Notebook
Can not connect to the internet need some type of code??
if you owner of the router and have username and password login to the router 192.168.1.1 go to wireless>wireless security and you going see code there,something like wpa code etc
Jun 12, 2009 | Linksys Wireless-G WRT54G Router
I have a siemens 6520 and on my dell 6000 laptop i can't access the internet even though i'm connected except on my dell 6400 laptop i can help?
You probably have set up some kind of security, and this is where I cant help you as I cant get into your router.
But, when you connect to your router to find out, USE A CABLE, do NOT connect wireless.
You may also find the wireless setup in your dell 6000, but you password and key code will most likely bee a row af stars.
/Teis
Vote if this helped you
Nov 30, 2008 | Siemens SpeedStream 2624 Router...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
418 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
