Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
MY LAUNDRY MACHINE
I BOUGHT MY LAUNDRY MACHINE A MONTH AGO AND I JUST HAD A PROBLEM THE MESSAGE ON THE MACHINE IS SUDS OR BLOCKED PUMP?? I MAYBE FIND THE ANSWER ON THE MESSAGES POSTED, THERE IS A PLASTIC COVER ON THE FRONT BOTTOM OF THE MACHINE I AM AFRAID TO BREAK IT COULD YOU TELL ME HOW I CAN OPEN IT IS THERE A WAY?? THANK YOU SO MUCH
I am getting the same error once in a while. Has anyone found the source of the problem?
Posted on Jan 24, 2008
  • 183 Answers
Check instruction book, it just prizes off. Regards Advisor
Posted on Aug 23, 2007
SOURCE:
Message "suds" appeared on my Magtag laundry machine
There is a panel at the bottom front of your machine. Remove the 3 - 4 screws at the bottom of the panel. Inside the panel you will find Service Codes and other useful info. It's a good place to keep them so my advice is to put them back when done with them. It is indicating "suds" because you are either using too much detergent, wrong kind of detergent (make sure it's high-efficiency detergent) or you need to clean the catch basket on the drain pump.
The owner's manual can be downloaded here:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/user-manuals/manual-downloads/Model-MAH2400AWW/3048/0153200?modelNumber=MAH2400AWW&diagramPageId=&documentId=
Hope this helps.
Dec 24, 2012 | Maytag Washing Machines
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
How would i solve problems regarding fault 37? please help.... problem happen 1 month ago & I haven't tried to fix it
Hi FUATALEVU.Just read your posting.Now error code 37 mean you have a pump block error.This means either your pump is blocked or jammed or the pump could be faulty or the motor controller is faulty or the pressure switch tube for water level is blocked.Does your machine drain the water out of the bowl?Where is the water draining to?Is it into a laundry sink or somewhere else?What is the model number of your machine?Please reply with additional information on the questions and I am sure I will be able to help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel Washing Machines
I'm getting An F2 message on my washer followed by a beep. The washer is not draining correctly.
F2 is a suds problem.
There is an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. Once a month, run the machine on the hot water cycle with a cup of bleach. This will clear out any suds build-up. Good luck :)
Jul 13, 2009 | Kenmore Washing Machines
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
111 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
