Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Please help. I had a lightening strike a few days ago which messed up many of my appliance including my Fisher and Paykel DEGX1 Electric Dryer. I pressed the reset button on my heating elemint after it wouldn't heat and it started heating. Problem fixed right? Wrong. Now the dryer element continually stays warm even when it isn't running thru a cycle. I have to unlug the dryer every time after I dry my cloths to stop the element from heating. I haven't take out the element for inspection yet but will do so tomorrow. Does any one out there have any suggestions for repair. Thanks in advance. Any help will be much appreciated.
  • 3 more comments
  • MikeyPix Aug 25, 2007
    Thanks for the help. I chesh all of the elements which are 4 offset rows of about 4 inch springs. I inspected all of them carefully 3 times and did not find on that was broken. Do you have any other suggestions? Again, thanks in advance. Any help will be much appreciated.
  • Steve Jan 03, 2009
    I had the exact same problem with my Fisher and Paykel DEGX1 Dryer. Even when turned off, the clothes were always warm when I emptied the dryer no matter how long it had been since the dryer completed the cycle.
    SolutionGuy was right on the money. I unplugged the dryer and removed the heating element. Just as he had described, one of the coils in the front had broken off and had fallen against the case. Because it was only half an inch from the top, I was able to stretch the spring coil and reattach it and then removed the broken tip. The dryer works fine. Thanks!!
  • Anonymous Mar 16, 2014
    mcg8000aww top box always a little warm, even when both top and bottom are off. Inside top back wall warm. Sounds like a heating element is on. Only if I unplug it does it cool off.Thx in advance for your help.
    President:
  • 331 Answers
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Posted on Aug 23, 2007
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
hi how are you...my name is michael...you said you reset the manuel reset on the hi limit ....sounds like one of your heaters is staying on ...ran into a problem a month ago....the control board on the bottom right side was keeping power on to one of the heaters..just plug in the dryer...take front off of dryer,front panel...put your head down by the heater ,see if its coming on an off..do not touch an thing ,make sure not to touch anything...so you dont get shocked...if it is the problem replace the main control on bottom...number for fisher an paykel..1-888-936-7872...my phone if need futher assitance is 1-843-384-8474...take care...hope this helps .....doctor airr appliance repair...michael....
Mar 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer runs as normal just doesnt put out any heat.
Usually when an electric dryer runs but stops heating, the heating element has failed and needs replacing. I don't know if you are a do-it-yourself type, but you can get the model/make/serial information and obtain the correct element at your appliance parts store.
I hope this helps... Good luck.
Oct 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Need to reset fisher paykel DEGX1
That appliance is fairly complicated. If you want to service it yourslef, my honest answer is to get the factory service manual from fisher paykel. You can get it here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Dec 12, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel Heating Element.
you have eather a bad timer or bad motor .
Nov 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel degx1 electric dryer
Restricted venting is the most likely cause, they did change the thermostats a couple years ago. the small t-stats should look cut out on the metal side they should not be solid, also check to make sure the elements are not shorted to ground.
Feb 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
533 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
Virgil Watts
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
