Try forgetting the wifi and connect it again.
if doesn't work, try restarting your router. just make sure you wait about 30 seconds before starting your router again.
check channel , try to change channel to 6,11 . check the long way between your device and router . if not soluted , try another pc to check disconnection , if disconnected the problem with your wireless router , if not the problem with your wireless device
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
I suggest you to do a hard reset on your router. Press the reset button at the back of the router for 20 seconds then unplug the power for 1 minute. Then reconfigure your PPPoE settings. On the Setup page of the router, make sure to choose the "Keep Alive" option.
