Question about Konica Minolta DiMAGE G530 Digital Camera
Memory card my camera is not responding to the memory card and will not take pictures i have used the card twice before the same camera
  • shamya17 Jan 05, 2008
    its not taking any pictures and every time i press mode the camera turns off i tried everything but nothings working what can i do?
  • renate_niess Apr 22, 2009
    We have a SD card in the camera but when we turn on the camera he says NO CARD. I also tried to format the SD card via the camera but then we get the same respons.
    Champion:
  • 217 Answers
Try to format card first in your camera not in pc. or you may try another card. Always format card in your camera not in pc!
Posted on Sep 08, 2007
SOURCE:
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
Ricoh Caplio R5. Have used cable transfer of pictures to my PC twice , but now the plug will not enter the camera socket.
hi!!!
try to replaced your usb plug
or removed the memory card and plug in
memory card reader!!!
if you want to move the pic to the computer
Sep 23, 2008 | Cameras
How to fix Internal memory card
Delete pictures from internal memory to make more space available. Better yet, insert a compatible memory card so that subsequent pictures go onto the memory card instead of into internal memory.
I'm sorry I can't tell you what type of memory card to use, since you declined to state what camera you're using. If you need further assistance, please feel free to respond to this post and specify the make and model of your camera.
Feb 07, 2012 | Cameras
Just purchase a 512mb memory card for my Fuji A330 I am able to take one picture but when I attemp to take a second picture in get the message "Write error" and it will not record that picture. ...
The A330 was first introduced in March of 2004 when a 512mb memory card would have cost more then the camera. First thing to mind with this problem has the "new" 512mb card been formatted to this camera? You may want to format the card twice and try it again. I know this may sound odd but even with my "older" Pro camera (5 Years) I had to download new updates to allow it to accept anything beyond an 4gig Memory card
Nov 24, 2010 | Fuji Cameras
Control Button Problem
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory and then promise yourself to never use it again.
May 11, 2010 | Cameras
Placed a new sd-hc card in an Easyshare Z650, camera responds "Memory card requires formating" hit continue twice and formatting will not take place. what are my options?
go to the menu and push (format memory card) then a a warning will come up that says (Warning Formating card will erase all that is on the care) push OK and it should format in might take some time !!Good Luck!!:)
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
I can only take 5 pictures with this camera before it says that the card is full. i have already changed the card twice is there something wrong with the camera or the card
This sounds like a problem with the memory card.
Your camera has 19MB of internal memory (used to take test photos in the shop usually) which is what the camera is using here.
You may need to format the memory card before use, assuming it is inserted into the camera correctly.
I have linked to the camera's instructions (PDF Format). Follow the details on page 30 describing how to format your memory card. Please also read through the set up at the beginning to ensure the card is inserted correctly. Thanks
Dec 24, 2009 | Olympus FE-46 Digital Camera
After I take a photo my camera says it's "busy, please wait" for about 10 seconds. I bought and formatted a new SD 4 GB card and it stopped doing that, so I thought it was good. After about a week, it...
I was having the same problem and contacted Casio. The issue seems to be that there are pictures/video on your internal camera memory which is conflicting with the memory card. Here is the fix:
Turn of the camera and take out your memory card Turn on the camera, click menu, setup, hit the up circle twice and click reset and click reset again until the camera resets
Then click menu again, setup, hit the up circle twice and click format, click format again until the camera formats
(This will delete the pictures from your memory card so make sure you have them saved) Turn off the camera and put your memory card back in, turn the camera on again. Repeat the format process for your memory card and you will be good to go!
Nov 02, 2009 | Casio Exilim EX-S12 Digital Camera
Take pictures but not saved so i have no pictures on my camera
The only way this could happen is if there's no memory card in the camera.
Easiest solution is to take the camera with you to Best Buy, hand it to someone in the digital camera department, and ask them for a compatible memory card.  They'll most likely respond asking you how many pictures you want to store on it.  You'll respond accordingly, hand him/her a debit/credit card, and be on your way.
Mar 18, 2009 | Canon PowerShot A570 IS Digital Camera
Memory card problem
hi
I was happily using Cannon IXUS 750on one of my long vacations when the memory card almost got full. perhaps I clicked once or twice to take a picture when the card was full. ever since the camera displays Memory Card Error.
These are almost all the photos I took on my camera since a long time now. Could anybody pleeeese help me in retrieving my photos and recordings?
thanks v much
Nahar
Oct 30, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Konica Minolta DiMAGE G530 Digital Camera Logo
77 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
