Question about Compaq Armada M700 Notebook
Laptop wont turn on
Well i was on the laptop with an ac cord and out of no where the backlight on the screen turned off so i ttying shutting it down and hasnt been able to turn on sense and the power light wont light up at all so im hoping its the cord but i dont know why the backlight turned off
    Problem Solver:
  • 13 Answers
Are there any noises like its attempting to start up? Any beeping, fans running? If there are and the activitity lights are flashing, but just the monitor is off, than I would definatly say there is probably a bad connection between the motherboard, and monitor.
Posted on Aug 23, 2007
Acer Aspire One D255-2256 will boot and shut down but when shut off screen turns white until I unplug AC Adapter. I can power back up and boots but when shut down as long as AC adapter is plugged in screen...
Graphics chip may have failed. If screen is white there is no information being sent to the screen, but the backlight is working fine. The Graphics chip may not be replaced, but the motherboard replacement is the usual fix for this issue. There may also be a loose cable beneath the case above the keyboard, which connects the screen to the motherboard.
Sep 28, 2013 | Acer Computers & Internet
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
I have a problem with my sony vaio!it seems to crush when i move the charger!its not shutting down but the scen is off and then i have to remove the charger so it shuts down and turn it on again!plus it...
It sounds like a loose connection in the charger cord or the AC jack. If the laptop is pulled by the cord it could have loosened/damaged the AC jack. If you remove the battery and only use the AC cord does the problem change? if you only use the battery and no AC cord does that change the problem? When Power is removed, without a proper shut down, the machine sees it as a crash therefore the disk check and black screen with boot options.
Nov 18, 2012 | Sony VAIO VGNBX740NS5 Notebook
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Wont power up, today.
try doing this
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can. if not, its ok
  3. press and hold down the power button for 7-10secs even without the ac adapter and the battery to release static electricity
  4. reconnect ac and battery
  5. try turning it on
Jan 26, 2010 | Sony VAIO VGN-N110G/W Notebook
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Screen wont turn on
remove the battery and the power from the laptop.....then press and hold down the power button for 20 seconds ...... attach the AC power only and turn on the laptop this should turn on the system.
This drains the capacitors on the system (safety feature of laptops ... quite common)
If this does not work remove the Ram and reseat it ... something has either come loose or the backlight on the LCD has gone bad.
Oct 06, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
My hp laptop screen wont turn on.
You have a bad backlight or backlight inverter , that need to replace. Bring the laptop to expert technician.
Jul 24, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Compaq Armada M700 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
