Question about Zapco Reference 200 Car Audio Amplifier
Zapco ag 350
Will not power up does not blow fuse what will cause this?
    Problem Solver:
  • 18 Answers
Check your ground and make sure it is properly grounded ....it needs to be a very clean paint/gum free area tightly bolted.  Next Check and make sure you are recieving your 12 volts (not running)  13 (running)    by placing your test leads from positive to ground...... then make sure your power remote from your head unit is putting out voltage.
Posted on Oct 13, 2007
SOURCE:
Do i have the right fuse
This speaker at full power draws average 1.3A at 230V and 2.5A at 120V. Mackie's recommended fuses are in line with this so your fuse is actually too high a rating. It is possible you are using cheap fast blow fuses or are over-driving the speaker (which should cause the fuse to blow) These speakers are only capable of 118db sustained (@1M) so cannot be expected to cope with anything but small venues or gentle music.
Dec 07, 2012 | Mackie Srm 350
My 2002 f350 diesel keeps blowing the fuel pump fuse every couple of miles. What is causing this? I changed the filter and it made it worse.
the problem could be the fuel pump fuses only blow when they are overloaded ie. if you have a 15 amp fuse & the fuel pump or whatever is drawing 20 amps the fuse will blow,if you are using the right amp fuse the fuel pump is drawing too much power & may be faulty or there is a problem with the wiring, a loose connection or the like.....hope this helps....cheers
Aug 14, 2010 | 1988 Ford F 350
Replace fuses No power on no standbyby power LED Just nothing
Are you trying to say it's blowing fuses? Stop wasting fuses and risking a fire.
Disconnect the speakers, see what happens. If it keeps blowing fuses it needs a real pro to look at it. Internet doesn't help.
Feb 25, 2010 | Teac AG-V8060 Receiver
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
Fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Mar 30, 2009 | Teac AG-V3050 Receiver
Repair service for AG1000 Zapco Amp.
Is it blowing the three 30 amp on-board fuses?
To have 3 speakers bridged, each speaker must have at least a 12 ohm impedance (assuming that all speakers are connected in parallel). If you're running a load lower than 4 ohms (mono), the amp will likely fail.
The fuses don't blow right away because they are cold at first. As they heat up, they can blow more easily (even though the current draw hasn't increased).
Aug 10, 2008 | Car Audio & Video
Teac ag-d9320 5.1 receiver fuse
Make sure the fuse you put in matches the power requirement of the device you're installing the fuse into, putting a fuse that does not handle the current will cause this, but do not overshoot as this may fry your device - it must match. If you know it's matched, then the device you're installing the fuse into may be faulty in such a way that it is drawing the wrong amount of power. This can be due to the power supply on the unit.
Sep 07, 2007 | Teac AG-D9320 Receiver
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Zapco Reference 200 Car Audio Amplifier Logo
274 people viewed this question
Top Zapco Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
