Question about Zenith DVT412 System
Progressive scanning issues
I got stuck on progressive mode, and I realize that I need to count the number of clicks to reset it, but I have no idea what that number is....any help?
  • 2 more comments
  • Darcymc Dec 02, 2007
    I can not see the picture on the screen I have sound but no picture, I have checked the connections and they are all fine.
  • coastwiseguy Dec 16, 2007
    I have the same problem. Can't see the screen to use Setup. I tried holding the stop button to reset the system and I tired counting seven clicks down, "enter" one click to the right, one click up and then "enter: again but it doesn't seem to work. Every once in a while I see a distorted blue Zenith screen but I can't read it to use it
  • mmakar Dec 21, 2007
    I've got the same problem, hook it up to the tv progressive scan and no signal. I've pressed stop, and have counted to reset progressive scan but no luck. No support from Zenith either, they took my phone number and waiting couple days now for a call back.
  • runni bunni May 24, 2008
    Im stuck in progressive scan and i have no signal- can still hear movie play help
Thanks it help me very much
Posted on Jan 21, 2009
I used the STOP button solution and it worked. Thank you!
Posted on Sep 22, 2008
Perfect... thanks for the click instructions
Posted on Mar 06, 2008
Setup button
7 clicks down, press enter, one click right, one click up, press enter.
Posted on Oct 27, 2007
My xbv410 is stuck on progressive scan mode. I
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Mar 13, 2010 | Zenith XBV442 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
My home theater got stuck in progressive scan mode
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Sep 07, 2006 | Zenith DVT412 System
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Zenith DVT412 System Logo
161 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
