Question about Proview PL713S 17" Flat Panel LCD Monitor
Screensaver will not come on
I have a PL713S monitor that I have had for about 3 yrs. I cannot get the screensaver to come on. I have tried everything I can think of - no luck. Every once in a while it will come on for a few seconds but after I use the computer it will not come back on. Does anyone have an idea on how to fix this? Thanks
  • George49 Apr 26, 2008
    I have an emachine about 3 years old.....it kept shutting off by it's self.....I determined it was either a cpu fan or the powersupply......I installed a new 300 watt ATX pentium 4 power supply.....this has stopped the continuous shutdowns.....only problem is now....I have no screen saver....it's set to come on after 15 minutes of no use.....I have tried changing all the settings but still no luck......I have a HP w1907 monitor.....and before I changed the power supply......the screen saver always worked.....any Ideas???
Try connecting another moniter, and see if you still have the same problem. If you still have the problem with the other moniter its most likely your OS
Posted on Aug 23, 2007
SOURCE:
I cannot find the power cord to my monitor. Where can I get a new one?
The power cord can be purchased at a computer shop of your choice, standard 3 pin power cable. Same as that used for the power to your computer.
damnor01
Nov 22, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Blurry screen on proview tft monitor
Try to adjust the picture adjustment.Like the contrast and brightness
Oct 05, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Jumpy monitor
Cheak the montor cable;set up the ups away from the monitor.even the problem is occured then problem with the circuit of the monitor.
Feb 13, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
My screen keeps going black any ideas?
If it's not showing anything and goes to sleep mode, then did you try to select the proper input from the monitor's on-screen menu?
Otherwise I can't help you unless you are more specific - when does it go black, right away or after 10 minutes of watching a movie for example?...
Oct 26, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Dell monitor screen jumps and screensaver won't ever turn on.
first turn hibernate off. this is probably causing problem with your screensaver. when you say your screen jumps that leads me to believe that your monitor is probably on its way out. If you can try to hook up a diffferent monitor and see if you have the same results
Dec 30, 2008 | E-Machines eMachines Desktop PC
My proview PL713s will not display an image!
I'm having the same problem. Did you ever figure what went wrong?
Aug 02, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Beware this monitor! PL713s
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. www.tigerdirect.com www.newegg.com Good luck
Aug 27, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
26 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
