Question about Motorola Mobility RAZR V3c Cellular Phone
White screen Im going to trade in my RAZR v3c, but in the meantime, is there some way I can get the white screen to start working again? Turning it off or removing the battery used to work, but it is being very stubborn right now.
I tried many remedies (new flex cable,cleaning connectors, new LCD board, taping the flex connectors to the board), but the issue persisted. Finally, the best solution came using a piece of toilet paper folded a few times and cut to fit. The TP acted as padding between the flex connector and the board (adding more, even pressure to the connector) and, more importantly, kept the metal piece inside from shorting out parts of the main PCB. It makes sense as often times my phone would work fine until pressure was applied to certain, seemingly random ares of the phone. Now it doesn't. or hasn't since I tried this. Also tried it on another v3c i had with the same problem. Fixed that one, too. Hope this helps someone out there. Also, this is the last time I buy a phone from eBay.
Posted on Oct 02, 2007
Open and close it a bunch of times. it works for me.
Posted on Aug 29, 2007
    New Friend:
  • 53 Answers
You can start by taking the cover below the battery off using a Torx 6 driver, unplugging the "flex" cable and cleaning the connectors. This will probably be a temporary solution as the connector most likely needs to be replaced which is a much more complicated process. If the connector is not the problem you may need a new LCD module or new flex which can be very costly especially if you are due for a new phone.
Posted on Sep 06, 2007
SOURCE:
My razr keeps going to a white screen. fix??
to make it sure bring your mobile to a service center i think you have a problem in your screen.
thanks,
Jun 03, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
V3c RAZR white screen at shut off only
can you do formatting? format it now, their is some program have deleted in your phone. i can format a cellphone, but in nokia. maybe i will find a way to solve your very little problem. i have a problem too! can you solve it? my problem is your phone.
Mar 13, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motoroa Razr V3c phone screen
Try removing battery, hold power button for 15 seconds, but battery back in and power up. This should work.
Jun 25, 2008 | Motorola Mobility RAZR V3c Cellular Phone
My razr v3c speaker phone key turns on and off by itself
have the phone keypad flex file reflash in the phone.
Or take the phone and have the flexcable replaced
Nov 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Phone has white screen
There is a panel behind the display that is damaged..This problem is common in all phones..You might want to go to a Motorola service center to get it fixed...
Nov 04, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Bootloader usb init razr v3m
motorola phone boot loader.
Software or the program of the phone has damage'
by using Smart Clip box you re program your mobile,
as they said the phone numbers, pics., songs, and video or all the files that you saved in your phone will be lost...
Aug 31, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
