Question about Philips Magnavox 27MT5405 TV
Magnavox 27MT5405 screen turning green on and off
My magnavox is less than 2 yrs old and the picture is turning green off and on. I called tech. support and they said that the tube might be going and that I should contact a repair shop...where I will have to pay for it!..because the warranty is only good for one year...of course!! I am wondering how many other people have had this problem around the 2yr mark. Perhaps magnavox should do something to compensate people if this seems to be an issue amongst the model, not just one televison.
  • kdl2 Jul 30, 2008
    same problem but mine is about 5 months.
SOURCE:
SOURCE: MAGNAVOX 51MP6200D/37
I also have the same problem this TV is garbage!! everywere I go on the internet I here the same thing, but NO solution has anyone fix there TV ,and what was it??????
Posted on Jul 26, 2008
TVtechmaniac
  • 140 Answers
SOURCE: tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Posted on Aug 30, 2007
SOURCE: 51" Magnavox projection TV
same with mine. Two things that they have to install and they need the whole tv there to fix it and run it for a week. Cost 500.00!!!
Posted on Sep 30, 2007
  • 1779 Answers
SOURCE: magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Posted on Feb 18, 2008
  • 52 Answers
SOURCE: Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Posted on Mar 09, 2008
The picture is out of focus for all inputs.
the tv is not worth fixing,get a flat screen lcd hdtv,here is the manual, Philips Magnavox 27MT5405 Product Manual
May 08, 2015 | Philips Magnavox 27MT5405 TV
Magnavox tv about 11 years old does not turn on at all what is the problem? all connections are ok
Magnavox are a generally cheap brand of television so 11 years out of the product is a good run
i would assume that the power supply inside the Tv has died, you could probably get it repaired, but it would be most likely cheaper just to buy a new TV.
Mar 05, 2011 | Philips Magnavox 27MT5405 TV
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
Blurry picture
It really depends on your level of expertise. Usually this is technically a very involved repair
Mar 13, 2009 | Televison & Video
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
I had the a similar issue. My TV broke - no sound and no video but the power light was still on.
He fixed my TV in less than 30 minutes by replacing a bad IC chip. He informed me that this is a very common problem with the older Magnavox TV sets and that its typicaly the same chip that fails.
I spent over 300.00 for the repair. The parts cost less than 20.00.
To help others in the same boat I put together a how to guide and parts kit on www.magnavoxhelp.com .  I'm not sure if it will work for you but it may be worth a shot.
Jan 05, 2008 | Philips 60PP9363 60" Rear Projection...
60" Philips Magnavox Projection TV Red Screen
You can also check to see if you have bad fluid problems, by looking down in your crt's with a flashlight when you unplug your set and see if you can notice any particles that should not be there. Look at all three and see if there is a difference. It should be clear, if not then you need to change fluid and clean.
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Dec 17, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 27MT5405 TV problem with color
hi sir that thing hapen when the magnetic field around the screen is varies evry time the tv set is switched off then on after an hour may be , it comes to its normal magnetic field state and when not so there are two reasons 1- check for around the tv for any magnetic items ,speakers , cassette recorder or any magnetic motors clear the around electric items if not working after an hour of reset then refer to 2 2- there is an electronic element inside calles PTC it should be deffect it is a small three legs element and is giving the first power to the colis around the screen to make proper magnetic field check it by qualified person please please don't forget to rate the solution and remember i am here at your service regards ]
Apr 30, 2007 | Philips Magnavox 27MT5405 TV
Philips Magnavox 27MT5405 TV Logo
294 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
