Bose 3 2 1 GSX System
Problem for Bose 3 2 1 GSX System
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
By jtabeart on Mar 25, 2009
I have a Bose 3-2-1 system and I want to connect it to a Samsung LCD monitor. The video output choices on the Bose are S-Video, Composite Video and Component Video. I have chosen to use Component Video.
The input choices on the Ssmsung monitor are VGA, HDMI and DVI-D.
The first connection I attempted was using a cable that had component video connections at one end and VGA at the other. It didn't work at all. I know the monitor VGA port is working, as I have successfully connected two computers using a VGA cable.
The second connection I attempted was a component video cable connected from the Bose to a signal converter, which reportedly converts from component video to HDMI to enable older analogue components to home theatre systems. I then connected an HDMI cable from the signal converter to the HDMI port on the monitor. A message is displayed on the monitor, telling me the resolution is not optimal. No DVD output makes it on to the screen and the Bose on-screen menu does not appear on the screen, so I can't check or change any of the Bose dispaly settings.
Any advice on how to get this combination working would be gratefully received.
Thankyou.
Best Solution
posted on Oct 14, 2009
Very Helpful)
white797
Rank: Apprentice
Rating: 100%, 2 votes
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Bose 3 2 1 GSX System
Questions and Unsolved Problems for Bose 3 2 1 GSX System
Do you recommend Bose 3 2 1 GSX System?
Answer
Answer
the dvd/cd tray is stuck in ours also (bose 321). cleaned the dvd, put it in the tray, and now the... (More)
Answer
my system keeps shutting off after a while
Answer
Bose 321 DVD player is making a noise when watching a movie and then freezes this goes on and on... (More)
Answer
i bought this a few years ago and now for some reason when i put a dvd in the picture comes out... (More)
Describe your Home Theater Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
in Van Nuys, CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
