Question about Jenn-Air JER8850 Electric Kitchen Range
Clock not working
The display on the electronic control clock is not keeping time and the numbers are fuzzy. I've tried clearing it and unpluging the range, it didn't work. Any Suggestions?
  • 725 Answers
You may have moisture in the conrtol clock have you baked some steamy things? the fix is a new control clock. let me know thanks
Posted on Aug 23, 2007
I'm getting an F1 error code on the display. Unplugging the stove overnight has cleared it, but it keeps coming back. I'm unable to locate my owner's manual.
Hi hammerpville,
The F1 error that you're getting means that there's an electronic oven control failure. To address this issue you have to replace electronic oven control (also called EOC or clock).
Hope this helps.
Thank you for using FixYa.
Aug 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
Model # arg7600ww. Display clock keeps flashing,
The eoc has gone bad. Clock control. You will need the manufacturers number also starts with a P when ordering this part. Hope this helps.
Mar 09, 2010 | Amana Kitchen Ranges
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 21, 2008 | Microwave Ovens
My clock stopped working on the display
The plug on your range may not be completely inserted into the outlet.
Clear all functions and see if the clock unfreezes
After all this, if the clock digits light up, and you still can't use any clock functions, it may be time for a new control panel.
Nov 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Nov 08, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Projection display
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Jan 11, 2007 | Homedics SS-4000 Clock Radio
Jenn-Air JER8850 Electric Kitchen Range Logo
109 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
