Question about Canon PowerShot A530 Digital Camera
LENS ERROR I have a Lens Error which indicates it will turn the power off. I took the camera apart and found a stripped gear. My problem is getting it back together as i dont have a service manual or diagram and cant remember how to get it back together.
  • Larry Scott
    Larry Scott Aug 26, 2007
    The solution is not specific enough. What i want to know is what is the flexwire? The gear was already damaged and im putting a different one in thats fine. Got any pictures or instructions on how to align lens and get it back together?
  • 169 Answers
It is difficult to put back the lens assembly if you don't have any may damage the gear and the flexwire if you not properly align the lens...since you already open the lens try to not damage the gear and flexwire...dont' apply some power to the motor...just a manual operation to the lens when you align it...
Posted on Aug 26, 2007
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
My camera turns on , but shuts off right away. I just put in a new battery, but still have the same problem.
When a camera initializes, it checks certain functions, and extends the lens. When a lens is stuck, the gears driving it are usually either stuck or stripped. Dust or sand in the lens assembly can jam the len's gears. There are some things you can do try to fix this, unless the gear(s) are actually stripped, and in that case repair is needed. Here is a web page that explains the things you can try to free the lens, and get it working again.
The blog is about lens errors and stuck lens, so try the suggestions. They say about half the cameras can be fixed, trying their steps. If nothing works, the camera will have to be repaired. Make sure you get an estimate first, since the cost of repair can be sometimes be more than a new camera. Good luck, and hope this helps.
Jun 14, 2010 | Kodak EasyShare One Digital Camera
Camera turns on, then the lens will not come out but it sounds like its trying to, then camera shuts off (all this happens in about 1-2 seconds)
Sounds like a stripped gear in the lens assembly (the gear that drives the lens out). Not an easy, or inexpensive fix, if it is stripped. If could just be jammed, however. Here is a blog about the problem, and things you can try to get it working. They say about half the cameras with this kind of problem can be fixed, using their steps. The blog is about lens errors, but it's the same problem you're having, and applies.
Jun 10, 2010 | Kodak EASYSHARE M763 Digital Camera
I fixed the first problem..!
I fixed the "zoom error" problem..but to be honest I'm not exactly sure how..i found some "jewelers tools" and following instructions found on this sight,ever so carefully,started unscrewing screws.First I removed the lens shroud,made sure it was clean...nothing..still had zoom error so then proceeded to remove the back of the camera..looked around and kinda "shook" it out.There was one little screw left that was preventing me from getting to the gear box but it wouldnt budge and i was afraid of stripping the screw so I said heck with it and reassembled it..figured what the heck and turned it on OMG! imagine my thrill when the lens zoomed in and out just like it is supposed to! But then i inserted memory card,turned it on and got the "zoom error"message again followed by "no card". Now what?
Apr 13, 2009 | Fuji FinePix S304 Digital Camera
Camera lens stuck
this occured to me whilst using my Sony P200, took it appart and found the lens motor had basically jumped its gears and jammed, the only solution was to replace the lense section (as motor & gears were built in) as no other part was damaged but to do that it would be at least £70 and the camera had dropped value to £160 and i could get a better camera for that my advice get a new one. and sell the remains on eBay.
May 13, 2008 | Cameras
Click here for help on repairing e18 error
good luck my friend!
Hope you will save 150$ for the repair..
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Lens will not open
Good Day, if you hear gears trying to open the lens, then the lens assy is broken, no longer user serviceable. please call your nearest reliable shop(sony svc ctr) and ask for the lens assy price, if it fits your budget then you decide. For sure lens assy is defective. thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Camera turns on and then turns off.
It seems the camera has a lens problem. Probably one of the lens gear is broken or defective. When you try to shoot the lens moves to focus and jams in the middle of the focus so shutter will not release becasue it is not focused yet. There are couple of gears in the gear chain of the lens and it is plastic. the volume of pictures you took might have caused one of the gear to wear down. The solution is to rebuild or replace lens assy. and the cost may be around $100 in US.
Mar 20, 2007 | Fuji FinePix A330 Digital Camera
Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Dec 14, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A530 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
