Question about Philips 60P8341 60" Rear Projection Television
On off problem
My tv worked fine for years and now all of a sudden it went of. You try to turn it on and nothing happens. I unplugged it and let it set over night and when I plugged it back in it worked fine for about an hour then it does the same thing.
    Genius:
  • 1,153 Answers
Its either convergence or vertical problems. Do your set have color problems? If so Converg. The other is Vertical output bad a 7 pin IC on a heat sink
Posted on Aug 23, 2007
SOURCE:
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
My protron 32" lcd tv was playing and just died no power. I tried unplugging the tv to reset and nothing happen
Your power supply is dead. You can get one from POWER-ON.COM for about $64.00 including shipping and handling. My 32 inch went dead after only one year and I just got a new power supply and it works fine.
Nov 05, 2009 | Protron PLTV-32 Television
LG W22h2TQ monitor just turned black
easy way to find out go to bestbuy and purchase a video card and install it if everything works out its the video card if not then its the monitor that went bad if its still under warranty send it back and get a replacement,
Dec 15, 2008 | LG W2252TQ Monitor
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
