Question about Sharp 32F640 32" TV
Got wet My 3 yr old son was caught spraying windex in the livingroom, the tv was on but I thought nothing of it, about 30 min later, the tv started changing channels on its on. It would go up several channels then stop on one for a min and so on and so on. The remote control would not turn the tv off and neither would the off switch on the set.So I am assuming that my son sprayed the tv (which my son said he did spray the tv)but he pointed to the speaker holes and the input holes and said that was where he sprayed) My husband said to turn off the power switch and I did. That did turn off the tv, however when I turned the power switch back on and turned the on button on the tv, nothing happens? Will the tv dry out and if so what do we need to do for this to work, or has the tv had it? Thank you very much.
  • jamiec82 Aug 23, 2007
    Thanks. That could very well have been what happened. We took the tv out of the entertainment center and put another in last night, this morning I just tried to turn it on to see and it came back on so Im not sure if it dried out and is good now, or if it will mess up again but for the meanwhile it is working. If it goes crazy again I will get the board cleaned and buttons replaced. Thank you for your help! :)
  • Anonymous Jan 10, 2008
    tv remote does not work other then sound set up menu has a wrench on it and i can not change any settings
  • 398 Answers
Most likely he sprayed the screen, and the fluid dripped down onto the board where the pushbuttons are. The pushbuttons them became contaminated and shorted out inside. Usually, the damage done will not be reversed by drying the set out. He should not feel bad, though, because we see adults doing that all the time. The TV has not "had it", since it is quite easy to correct. The board should be cleaned and any defective pushbuttons replaced by a qualified tech.
Posted on Aug 23, 2007
SOURCE:
What to use on the t.v. screen to clean it?
Turn off power , touch screen to release static electricity , use plain old Windex and paper towels...
Nov 13, 2017 | Televison & Video
Son sprayed cleaner on tv.
I have not a clue what to tell you, but doubt the cleaner is the cause of this. In any case the TV is so old you will not be able to get parts.
Jul 09, 2017 | Televison & Video
My Pioneer VSX 820K will not turn on. Son sprayed some windex on it when it was on and it shut down.
More than likely the windex fried a channel or two. If you have a DVM you can find out wich chanel or channels is bad by checking each output transistor for each channel until you find the one that is shorted.
Jun 06, 2012 | Pioneer VSX1020K Receiver
Have a 2002 ion that sometimes wont start but if left for 10 mins will start up.
I have 2003 Saturn Ion. I had this problem over and over 2006 - 2008. IT IS THE IGNITION SWITCH. IT IS DEFECTIVE IN ALL ION'S.The replacement may be defective also, not sure. Mine was driving fine, went ino store for 1 hr came out stone cold dead, would not start and key **** in. Had to have towed to Saturn. They said it was battery and replaced battery.I said this did not make sense. 6 yr battery only 3 yr old , never weak start, never run down, in summer? It happened again 2 mo later. They tried to say battery , I said no. They checked battery. It was fine. Could not find problem. They did total electrical check. It happened again 1 mo later. drove into feed store. Went in came out it happened again. I got jump from someone 30 min later and started right up. 2 wks later same, I got jump 20 min later started. 1 mo late same. Sometimes it would just start up. Took to another Saturn place. They said Ignition switch, saturn was having big problem with this on Ions. Got changed and no problems for 1 yr. I was talking to repesentative at Saturn Headquarters. I told the problem. They said the ignition switch has an electrical component, or it is hooked to electrical component. THEY SAID IF I HAD JUST SAT THERE 20 MIN WITH KEY OFF, THE COMPUTER CHIP FOR IT WOULD HAVE RESET ITSELF WHEN IT COOLED DOWN AND I COULD HAVE STARTED IT EACH TIME. IT WAS BEST TO GET REPLACED AND NOT WORRY, BUT THIS WILL HELP YOU IN A STRESSFUL PINCH, UNTIL YOU CAN GET THE IGNITION SWITCH REPLACED. NOTE: Go to Auto Zone , O 'Reilleys, Pep Boys etc, get a repair manuel , CHILTON $ 23- $ 25 , for your year , make, model car. CHILTON IS MUCH BETTER THAN HAYES MANUEL. It is wonderful and many things you can do yourself.
Feb 09, 2010 | 2003 Saturn ION
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any...
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Nov 17, 2009 | LG 50PX1D 50 in. Plasma Television
2 yr old spayed approx 60ml of windex over the
The windex may have seeped up into the screen. It should dry in a few weeks.
Oct 03, 2009 | Joy Toshiba M105 S3002 Notebook
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sharp 32F640 32" TV Logo
116 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
