Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
Upright freezer it started beeping last week and it beeps all the time.
  • intreverend Jun 23, 2008
    Ours also beeps nonstop. Our electronic panel gives what looks like either a "6" or a "b" code error. In the past I have had trouble with the freezer not defrosting. I had a tech to the house who replaced all the defrosting components, but it frosted up again a few months later. I manually thawed it out myself the second time, but now I am getting the erratic behaviors described above--at least the freezer is staying cold (for now, at least). At any rate, it is not the smoke detector.
  • dtucker Sep 05, 2008
    I have the same problem but can not figure out how to get the electronic panel off to replace the battery without breaking the panel.
A code "b" is a low battery. Replace the battery, reset the alarm and off you go.
Posted on Jul 26, 2008
  • Kenmore Master
  • 4,656 Answers
I went on a call for a problem like you explained. I looked everywhere and found that a battery in a smoke detector was low and warning that it needed replacing. No insult, but the customer and I were both were a little supprised. Now I have not found a fridge beep yet, so if you have already found the answer please let me know. So we can pass the answer on to others that have had the problem you listed. I realize our response time is late, I just saw it today. Please tell me what you found, Thanks, JT
Posted on Oct 24, 2007
SOURCE:
My frigidare freezer upright after moving beeps hit reseat quits after a few hours starts beeping again freezes great
Sounds like a GPS locator issue! JUST KIDDING!
This site may help. There are just too many electronic anomalies that can cause this issue. I got lucky once by asking if they just had their dog RFID tagged and spayed or neutered. Turns out they did that week. The ID tag was on the same frequency as their dryer buzzer. They put a gum wrapper on the front of buzzer and problem solved.
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 07, 2017 | Freezers
Will not turn back on 3 beeps
remove the screw(s) and slide the cover towards the front (the cover over the control board near the wash/ice switch.) with the machine on carefully locate the reset button on top of the circuit board and push to reset..
Mar 18, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not making ice. When pressing the test button will start to make some and then beep about 3 times, then does not produce anymore ice.
Do not use test button. It test the functions of the board only. You have another issue. Need to know the number of beeps. Usually beeps a certain number of times, then hesitates,then beeps again.
Jul 27, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My Ice machine started beeping from the fuse last night and is not working
The beeping in ice machine is a code. Take off the electrical panel cover. Carefully look for and press the small reset button on the board. This will restart the machine. If it shuts off again call a service company out.
Oct 18, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My intergrated Beko fridge freezer keeps beeping. I have defrosted it but it still keeps beeping! Please help this driving me wild!
Tell me, what is the purpose of that beeping. There should be some indication. Lots of different alarms come up. Most common are when the evaporator fan does not transfer frost to the rest of the the fridge. So check fan for movement.
Sep 11, 2009 | Freezers
My ice machine only harvest 2 time and start to 3 beep eveaperater very clean no scales inside because i descale every 2 weeks can u help me
In most cases, there is a chart on the inside of the front cover. It may also be located on the side of the box where the control circuit board is located. It will tell you what the 3 beeps mean. Hoshi has a great tech support. It's worth the wait.
Feb 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Km 500 kae hoshizaki 3 beeps every 4 second compressor not coming on
put an amp probe on common wire at compressor and see what amps are when it tries to start. 40 to 60 is mechancially locked up compressor. kill power and test start and run capacitors. there is an thermal temp over load on the compressor that opens when comp gets hot from trying to start. gently remove and look for cracks or burned looking. . i saw one this week doing exact same and i have ordered the oem compressor start cap realy and run cap and drier and will put in all new gas. be sure to allow sufficient time when switched to ice for it to get to ref cycle, it may take 5 minutes starting with water purge, then fill, etc. good luck, call hoshizaki dist they are usually pretty helpful if you need a auth service rep in you area. i think they are three years warrantied!
Oct 25, 2008 | Hoshizaki Freezers
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
274 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
