Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Krups 867 will not light up led pad is dead
Last night we had a bad storm come threw my area. i dont know if that has anything to do with my problem. the clock was not on,only one small light was on where clock is. it will not power up on coffee side. the expresso control switch will light up when turned on. just will not make coffee. thanks!
  • cyclebookie Apr 21, 2008
    I jst had the same problem happen to my krups, this morning.
    did anyone find a solution
  • dpcssw Nov 30, 2008
    Same problem - no lights - outlet works... Any solutions?
Thanks! I figured it out...tested the wiring and found that one of the thermo fuses was blown (the one under the caraffe). I found a matching pair on eBay and after getting it, just soldered it in as a replacement. Everything works now- the LED, everything- in fact, I'm drinking a cup of coffee from the unit right now. The only issue that I'm now having is that it seems to take longer than before to make a pot and there is more guggling and just louder noise from the unit. I've checked all hoses and they are secure- I even added silicone to the joints to make sure no air was getting in. If it is, the crack or break is in a section of the aluminum pipes that I can't get to, but there are no leaks from the Krups, so who know. Still makes great coffee and this thing is at least 15 years old! David
Posted on Jan 20, 2009
I have a suggestion to try. I had the opposite problem in that the espresso side wouldn't work. Brewed coffee fine.
There is a small computer board inside this unit. You can access it by UNPLUGGING the unit from the power source, removing the carafe and all the "attachments" and then turning the unit upside down. Find two holes approximately the diameter of a pencil. Using a small Phillips head screwdriver that will reach, remove the two screws. The entire lid can be removed by unsnapping it gently. (Make sure to remove the steamer/boiler cover first) Don't break it, but just jiggle it and you'll hear small pops as it detaches.
Once open, and again, removed from the power source, you can unplug the small white plug from the printed circuit board. Then simply wait for a moment and then plug it back in. Make sure all the other wires are plugged in, and then flip the unit back over. Don't touch anything inside the power computer cavity and then plug the unit back in and see if it will operate properly once this "reset" is done. If so, unplug it, reverse the steps to reassemble the unit and you win.
No guarantees here. It worked for me. It's worth a try though, before you decide to throw the unit away. I've had mine for 13 years and used it nearly every day. Nice to have you back old friend....
Good Luck
Posted on Jan 19, 2009
I'm looking for the LED panel inside of it...I believe if I replace this I can get this working again...we've had ours for 21 years and it broke yesterday. I hate to do without this great machine. Someone can email me if they want (replace the "-at-" with @).
Posted on Sep 24, 2008
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
I bought a Night Owl Vision Cyclops 1 monocular marked Made in Russia from a man last weekend at a flea market. It is in pristine condition and the gentleman said it worked but he hadn't used it in a...
Hello, Is there two switches on the NV monocular? If so, one is for the IR illuminator and other is for turn the scope off/on. Also, does each switch have a LED associated with it? Green for turning on the monocular and red LED when the IR illuminator is on. Now the IR switch is a momentary switch once you push on the button it turn on IR. If you release the IR button it turns off the IR..
What do you mean by green lightening storm in the view finder? Generation 1 image intensifier tubes when ignited by 15KV it will glow green in the tube. If you look through the eye pieces there will be a green glow with fluctuating intensity as bright light impact the plate in the image tube. GB...stewbison
Aug 22, 2011 | Kalinka Zenit NV CH Russian Night Vision...
I dont have an instruction manual for a Krups coffee machine.
click on this link directly for user manual of Krupp 867 and yours is 866 but its the same.Download the complete
user guide (411 Ko)
------- This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 19, 2010 | Krups Coffee Makers & Espresso Machines
Krups 867 Bistro Coffeemaker
Jan 28, 2010 | Krups Caffe Bistro 867 Espresso & Coffee...
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Tv dead after storm
you could open it and look to see if the fuse is blown
Sep 22, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Coffee maker side will not work.
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
Sep 10, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Open Questions:
See all Krups Caffe Bistro 867 Espresso & Coffee Maker Questions
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
347 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
