Question about Sceptre X37sv-Naga 37 in. LCD Television
Replacing Sceptre Power supply
By now we all have figured out that these Sceptre power supplys are not reliable. My question is: are there after market solutions available? I have a 30SV Naga-III. Do I have to take the brick apart and try to repair it or can I get a new one somewhere? Thanks much.
  • 1 more comment
  • Anonymous Apr 30, 2008
    I have recently had my Sceptre power supply buzz, stop buzzing and CLICK. My 37" TV is now a paperweight. I am interested in replacing the power supply before forking over the dough for another TV/monitor.
  • Anonymous Dec 11, 2008
    IT DOES NOT WORK UNLESS YOU HIT IT
  • Anonymous Mar 22, 2014
    SOMES COMPONENTS ARE BURNED THAT WHY INEED A SHEMATIC MANY THANKS
The attached pictures are the back of our TV which is a Sceptre X30SV NAGA III. In ours the power supply is inside the vertical panel on the back right of the TV. The plug goes in the bottom of the panel and you remove the panel with the horizontal louvers with 4 screws to get at the power supply. A replacement power supply is from Delta Electronics part number ADP 180CB B , 24 Volts 7.5 amps 180 Watts that we reordered from here:
http://cgi.ebay.com/Delta-ADP-180CB-B-24V-7-5A-180W-4-Pin-Din_W0QQitemZ160268090373QQcmdZViewItem
Posted on Aug 08, 2008
Sceptre X505BV no power
Could be an open internal fuse or power supply failure
Jun 22, 2017 | Sceptre Televison & Video
Can a novice replace defective power board?
Hi Claudia,
everyone has to start somewhere, replacing a Power Supply Board is quite straightforward with a little common sense and safety precautions, there are many tutorials on you tube, you would probably find that someone has posted a tutorial on your actual model, here's an example of a power supply board swop, have a look at this one and others to gain an insight and decide then if its for you,
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 12, 2016 | Sceptre X405BV-FHD3 40 in. LCD HDTV
The blue power light just binks when it's plugged in, the power button doesn't even have to be pressed. is that the power supply or the logic board? (already ruled out inverter board)
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
Jul 15, 2010 | Sceptre Komodo X37SV 37 in. LCD Television
What power supply is the best
OCZ, Corsair, Thermaltake, CoolerMaster, Antec (voted 'most reliable power supply' by pcworld france), Enermax, Zalman. Any of these brands should do fine.
Don't buy a cheap one. Expect top ay between $60 and $150 in the US for a power supply)
Also, buy one that has a bit more power than the one you're replacing
Mar 27, 2010 | Dell (PS-5251-2DS) (M0148) 250-Watt Power...
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
TV will not power up
My Sceptre X30SV had no power. I unscrewed the panel where the power supply is (in the back of the tv) and unplugged the power brick. Shortly after I plugged it back in and it has worked for the past 24 hours. I'm thinking my power supply is on its way out. I have purchased a voltage meter, how do I go about testing the power brick?
Thanks for your help in advance!
May 28, 2009 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Replacing Capacitor on LCD Monitor
That is good advice. Always replace with same or higher voltage rating. Also make sure it is put in the right way around.
Sep 21, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X37SV no blue light
I don't think those are capacitors. They are varistors and (as a pair) they are in series between the mains and the load. Current flows through them so if they have dry-jointed then you have an open circuit and no current flow. This seems to be a recurrent problem. I'm trying to locate a replacement but I can't find the characteristics of the SCK 085 listed anywhere.
My guess is that this is a US problem only. In other countries with higher mains voltage, the power supply draws a lower current and doesn't cause the varistors to overheat.
Aug 28, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 in. LCD Television Logo
3,423 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
