Question about LG LB8000ER Air Conditioner
Troubleshooting My window unit is 3 years old. It is spitting water out of the vents and sounds like it is shaving ice. Could my coils be freezing up, and what do I need to do to resolve this problem? I have turned it off for over 8 hours, but after it runs for less than one hour it starts up spitting water and making noise again.
  • Button56 May 06, 2008
    have the same problem and I tillted it back slightly. There doesn't seem to be any water pooling up in the back only in the front.
  • brian64 Aug 18, 2008
    water in ac wont drain
  • 725 Answers
First I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Posted on Aug 23, 2007
SOURCE:
Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Oct 03, 2014 | Heating & Cooling
My ac is a window unit and 1 year old it is
is the filter clean clean coils and drain pan please give me a vote
Sep 19, 2010 | GE Heating & Cooling
KITCHEN AID SIDE BY SIDE KSRP25FSMS01 We first niticed the freezer and fridge not being cold enough, then it stopped making ice. The freezer would not freeze things but still felt cold. I cleaned the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 18, 2010 | KitchenAid Refrigerators
Throws or sprays lots of water out the front on a daily basis which is soaking the carpet and furniture. The window unit is over ten years old and has been running non-stop for at least 5 years.
It sounds like that unit is getting a bit low on charge and is freezing up a bit....maybe even needs a good cleaning of the indoor coil... that would make it freeze also.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 02, 2010 | Daewoo DSA-122L Air Conditioner
My unit is 3 years old. We have recently heard
sounds like the evap coil is freezing. it is frozen if you have low air flow. check the lines and see if your suction line is freezing. also check your filter. if you think your drain line is clogged cut the line and blow out with an air compressor or nitrogen. all you should need to fix the line would be a 3/4 in coupling or a union. hope this helps
May 31, 2010 | Goodman CLQ60AR61 Air Conditioner
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Freezr coil, vent and back panel of kenmore iced and not cooling
HI, Your auto defrost cycle has gone bad. Remove the rear inside freezer panel and check continuity on the defrost heater and bi-metal switch. The bi-metal has to be cold when testing it. If both parts show continuity, you will need to change the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Refrigerators
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
LG LB8000ER Air Conditioner Logo
385 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
