Question about Sony KV-32V35 TV
No power. I have a 1997 Sony KV-32V35 tv. Tv turned itself off while we were watching it. Now it won't turn on at all. Do I really have to spend $300 on a power supply?
  • 398 Answers
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Posted on Aug 23, 2007
SOURCE:
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv kv-20fv 300 power light just blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Apr 25, 2010 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Sony KV-32V26 turned off while watching, now I can't turn it on
I have a set I'm working on right now, same model number and symptoms. It is a fairly common problem and the repair consists of replacing 3 transistors, one resistor and one VDR (voltage dependent resistor), along with re-soldering some connections on the main PC board. You'll need a technician to do the work, and it will likely be well over $100 to repair. I would consider replacing the set with a HDTV model if you can afford to. The picture tube may be the next to go.
Apr 02, 2010 | Sony KV-32V26 32" TV
My TV does not have an image, does not turn on, what might be the problem?
The power supply is evetually the problem. Which is not recommanded to customer to fix. because of danger.Make sure your outlet has power comes to it or move the TV to another outlet, and try it.
Otherwise you may see a qualified technician
Oct 09, 2009 | Sony KV-32V35 TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Is the sony kv-32v35 digital ready?
if the tv is less than two yrs old than yes.
Dec 20, 2008 | Sony KV-32V35 TV
Sony kv 36xbr400 - Won't stay on
Problem is in the secondary power supply which provides power to high-voltage and scanning sections of main board. This is called BOARD D, and has the high-voltage section, flyback transformer, and control IC on it.
Can't be fixed by user, needs service tech and new part, around $300
Oct 12, 2008 | Sony KV-36XBR400 36" TV
Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
Sep 22, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony KV-32V35
Could be a problem in the shutdown circuit,in the HI Voltage detection circuit,or the flyback transformer. If your not a tech, you shouldnt be experimenting by adding parts as its going to knock you against the wall if it bites you. You should start out with a service manual and check the voiltages as now thinking it could be the power supply voltage regulator also. Please call a pro to assist you with this repair. Good Luck
Aug 02, 2006 | Sony KV-32V35 TV
Televison & Video Logo
144 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
