Our 52" Brushed Nickel Bellhaven Ceiling Fan has a "grinding" sound, however the unit seems to be balanced showing no signs of wobbling
SOURCE: Ceiling fan wobbles How do i balance it ??
you go to the hardware store and buy a ceiling fan balancing kit
SOURCE: Cannot stop the ceiling fan from wobbling. Have
I am trying to locate the peice that attaches to the ceiling that holds the fan for an encon model CD52, serial #9605. Where would I find this?
SOURCE: Hampton Bay fan has a grinding noise
I have worked on many fans because this fan is ten years old. I want to say that this fan has ball bearings in it. Have you tryed WD-40? If so did it work? Are you able to look inside, through the top of the fan to see if some thing is in its way?
Testimonial: "Nothing is in the way inside. I'll try the wd-40. Thanks. "
SOURCE: I would like to order a replacement light kit for
Hampton bay is an exclusiove brand of Home Depot. Yopu shopuld be able to get a new light kit to fit your fan there or try any lighting store or Lowes. You will need to bring the old one with you to compare the size of the mounting plate and the araingement of the mounting screws to the new kit.
SOURCE: Hampton Bay Carlsbad 52 in.
either you have a problem with the transmitter or with the electrican this is an easy job not to much can go wroung.lrt me see if i remember hook black to black white to white and hook up ground. good luck
