Question about Fedders X Chassis A3X05F2B Air Conditioner
Fedders window air
The compresser keeps kicks off
  • 50 Answers
Make sure the evaporator and condenser are clean. If so, is the blower motor still running when the compressor shuts off?
Posted on Aug 25, 2007
SOURCE:
Ac compressed not kicking on put a new relay and still not kicking on
2 things if its not above 45 degrees it wont come on , and did u check Freon level with gauge keep in mind while system is off it show a reading like its over filled so shoot some Freon in see if kicks on while engine is running
Feb 22, 2015 | 2000 Oldsmobile Intrigue
Why does Lawn tractor seems to have too much compression and kicks back on starter?
Your valve lash is out of adjustment causing the exhaust Valve to stay closed longer then it should, keeping compression in the cylinder trying to exhaust while in the compression stroke..not a hard job but must be done...good luck
May 22, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Dirtbike kick star
this happened with my sons pw50 where the piston ring had snapped and when it locked it was stuck bewteen the piston & bore
i would seek a shop or mechaninc to look at the top end and isnpect the piston & rings for wear or damage
dont keep kicking as this could result in further damage
Mar 20, 2014 | 2003 Yamaha YZ 125
2001 Yamaha TTR90 hard to start cold
My guess would be that you have dried out seals/gaskets taking away from the overall compression. This will either get better with use as everything lubes up or you will have to replace all that are leaking.
Mar 18, 2014 | Motorcycles
Can an 87 fxrs be kick started?
I've never heard such a thing...
But you have to have a kick starter first and I don't recall 87's having one. Correct me if I'm wrong or if the trans has been changed out then yes you could have one. But I've never heard of Harley's starting on the second compression stroke. Plus the modern after market ignition systems used without kick start transmissions are the same ones used with custom scoots that have a modern trans with the old look of the kick starter... Although with these high compression engines, compression releases are common place because neither the starter or kick starter could crank one without...
Dec 30, 2013 | Motorcycles
My atv is 110 cc and wont start the celiode keeps makeing a clacking noise as if its jamed i changed it and same thing what cani do
kick start right,? is it kicking over fine with your normal compression like last time you rode it????
Sep 25, 2013 | Cycling
AC compresser kicks in and out
You have a leak in the AC system and the refrigerant charge is low, this is a common failure on this make and model, have repaired dozens of them. You will need to replace the AC compressor and also reseal all the AC lines with the new and improved nitrile rubber green O ring seals. This job requires a car hoist and special tools an it is best left to an expert. Cost is about $1000.00
Jun 22, 2012 | 1996 Lincoln Continental
Have barely any compression at all but still starts after a lot of kicks.
turn off the key, hold the choke button and keep on kicking the crank handle for a few times but dont turn on the accellarator, After that turn on the key and release the choke button and slowly turn on the accellarator after every kick
Sep 13, 2010 | 2003 kawasaki KX 250
I have a 1997 Lincoln continental.When I turn on the a/c I can hear the compresser kick in but it goes right back off and the whole time the ac is running it keeps trying to kick in but keep cutting off. I...
It will be in the yellow section if the compressor isn't running. Go ahead and hook up the gauge. When the compressor kicks on the pressure should drop to below 15 and then the compressor should kick off. Is it doing this? If yes go ahead and add freon. The yellow section means the pressure is high but you only have to worry about it if the gauge reads in the yellow with the compressor kicked on.
Apr 29, 2009 | 1997 Lincoln Continental
Kickstart problem
Hi crazy
Your bike has an automatic de-compression lever that helps when starting. This mechanism will make it feel like the bike has low compression. If it is maladjusted, it may be causing the problem
check here for adjustment procedures to be sure that it is set up correctly.
Other than that, low compression pretty much means top end rebuild.
regards
robotek
Dec 16, 2008 | 1998 Honda XR 400R
Fedders X Chassis A3X05F2B Air Conditioner Logo
98 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
