Question about Panasonic DMRES15 DVD Recorder
DVD does not start set up automatically
After an energy breakdown, the DVD doesn't start setup. The clock is on O:OO and he display shows INSERT DISK and LD FVU
  • Anonymous Feb 15, 2009
    same
Hi Turtis,
Did you ever solve this?? I have a similar problem on my DMREZ25EB and got told it could be resolved by updating the firmware which is what the FVU is meant to mean. However, I can't find my version of the Firmware on the panasonic.com site. If you solved this could you let me know what you did.
Thanks,
Vee.
Posted on Nov 05, 2007
The inside H2 Bios on my LG x13 doesn't start and ask for a boot disk which I DON'T HAVE, can someone help?
My lg x13 shows also f2 and f10 for boot it doesnt go in bios on f2 and f10boot shows reltec cli k on it says insert disk but the laptop doest take a disk plse help
Jul 30, 2012 | LG X130 Netbook
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
I am trying to down load my new program off of a dvd. I am stuck. How do you do it
If your computer doesn't open the setup file automatically when the DVD is inserted, you can always insert the DVD, open My Computer (Windows)/ Finder (Mac), find the disk or disk drive, click it and open the contents of the DVD, find the setup/install file and manually run it.
Hopefully this helps and if there is another error please post it.
Jul 20, 2011 | Anna Banana Creative Design ChartMaker
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
I want to reinstall my window xp operating system i set the dvd rom as the first boot but it says not found
turn off your pc, open it, and check cables and connectors, check the jumper settings on your DVD drive. if you want, you can isolate the problem by simply connecting only the DVD, disconnect the Hard Drive and test.
Jul 07, 2009 | Microsoft Windows XP Professional
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
Panasonic DMRES15 DVD Recorder Logo
537 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
