Question about Harman Kardon AVR 7000
Scratchy noise from all surround mode except 3 channel
I have had this unit for quiet a while now. Before everything was working fine, but now the unit is not working properly. Here is the problem, when I play a movie or any cd selecting other surround mode, I'd get the scratchy noises and the unit will turn itself of. Only the 3 channel mode is working and I can only output the the two front speakers. I tried calling H/K tech for support but the unit warranty had expired a long time ago. Could it be the IC101 on the DSP board that were on the service bulletin board from H/K regarding the Logic 7 scratchy noise? Please help, I did not want to buy another receiver at this moment>
  • chris ZAMBROTTA
    chris ZAMBROTTA May 11, 2010
    how many capicitors did you change where did you get the replacements?can you give me a diagram or schematic?
    how much did it cost you?i brought a 7000 on ebay 4 350.00 i still can send it back,but if the repair is not too costly ill keep it.thank you
    chriszambrotta@yahoo.com
    i have multi meter how can i test the caps?
    New Friend:
  • 101 Answers
WHERE CAN I GET THE UPDATED OR CHANGES NEEDED IN MY SYSTEM? ITS FROM JANUYARY SO PROBABLY I NEED THAT PROCESSEOR CHANGE DO YOU THINK IT GOING TO BE COSTLY ,CAN YOU GIVE ME AN IDEA?
Posted on Jan 29, 2008
I believe that these receivers needs approx. 100 Electrolytic capacitors that will fix all these kinds of problems. Mine had to go in the shop recently, the tech working on it is normally quite thourough, however he troubleshot to some ribbon flat cables that were defective and their slotted push in connectors going from the DSP board to the front processor. HK once pointed that a bunch of electrolytic capacitors have dried up, hence would need to be replaced. I would have done the work myself, however the unit had an extended warranty, in this case I will get an exchanged unit, perhaps a unit of my choice, but I still want a Harman Kardon. The DSP processor is not always found to be faulty, however there is a change in the processor being used depending on your particular receiver's serial number.
good luck.
Posted on Jan 17, 2008
Left speaker is very quiet
This may be a capacitor problem, evaluate and replace if bad.
Feb 12, 2014 | Harmon Kardon AVR 700 A 5.1-channel...
On my recently installed Jensen VM9414, while playing a DVD, I can clearly hear the background noise/music, but I cannot hear the characters voices. I thought maybe it was the setup but have tried...
I've had this problem before, but not on this specific head unit. You most likely have your audio setup to 5.1 or other surround format, yet have nothing hooked up to the center channel output of the head unit.
Unless you've currently hooked up the center channel to an amplified speaker, or gotten out of a surround mode, you're not going to hear anything.
If you do have everything hooked up right and are sure the settings are correct, possibly a blown amp in the head unit.
Feb 28, 2011 | Jensen Vm9414 Car Video Player
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
Left channels do not work when using surround modes
Ohhhhhh, so it has NEVER worked for YOU and it needed fixing when you got it. That changes everything. And you don't have the manual??
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of this unit anyway.
Make sure everything is connected correctly.
Look it over and play around with it. Speaker setup needs to be done before anything else. Did you get the microphone that comes with it? If not, go to page 23 and start there.
Feb 16, 2010 | Denon AVR-1708 Receiver
No surround Technics SA-AX530
There is likely separate gain controls for your surround channels on this receiver and they are probably set at -10dB. Enter the setup menu labled "level" and increase the amount for each channel equally.
Jun 18, 2009 | Technics SA-AX530 Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Harman Kardon AVR 7000 Logo
362 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
