Question about Kenmore 40192 / 40199 Electric Single Oven
Hole underneath back left burner?
There is an open metal tube that runs from my oven to underneath the back left burner. Should it have a cap? It seems to be letting a lot of hot air out the oven, and my cooking times are way off.
    Problem Solver:
  • 6 Answers
It is your oven vent. It needs to be left open. There could be a calibration issue with your cooking times. Check the accuracy of your thermostat with an oven thermometer.
Posted on Aug 26, 2007
Her do I find the model number on my magic chef electric oven. Red light is on staying on? Burners and ovens are all off, What's or how do I find out what's wrong?
There should be an identification plate or label located somewhere (or hidden somewhere) on your oven that indicates model.
Mar 29, 2018 | Magic Chef Ovens
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
The top left front burner will not ignite. The igniter is sparking, but does not ignite burner. You can smell the gas. The burner will ignite with a match.
Hello
This sounds like the tube that runs from the burner to the ignitor is clogged. If you raise the top of the stove, look for that tube, take it out and run it under some hot water to remove the residue buildup. Replace the tube and try it again. My thought is that is the trouble,
Let me know how you make out, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Ovens
Oven will ignight but will not stay lit.
When the oven lighting mechanism lights the gas the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressore in the sensor pipe, the valve won't open and there is no gas to the burner.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that's not an issue, you can just coil any extra pipe up somewhere between the burner and the valve.
Jul 07, 2011 | Whirlpool Ovens
Kenmore Gas Range. Top burners work fine. Oven is slow to preheat. Igniter has a yellow glow and the burner lights within about 20-30 seconds later. However, the burner has a very small flame and it takes...
the ignitor should glow bright orange.it sounds like you have a weak ignitor but if the flame lites within 20 to 30 seconds it sounds like it's ok,it could be braking down though when it gets hot,it doesn't matter if it glows,it has to be putting out 3.2 amps,if you have an amp meter with a clamp on it you can read out the amps,if the broiler works ok i would change out the ignitor,then follow the tube down to the bottom and stick a paper clip in the orifice hole where the gas comes out and make sure that's clear,also there's a shutter on the tube to adjust the air flow,see if it's closed,it's usually almost wide open,check the tube to make sure the ignitor didn't burn a hole through it.i've found tubes with holes in them from a lazy ignitor,most of the time if there's a problem it will be the ignitor
Jan 23, 2011 | Ovens
I have a Maytag Oven Model CRG9800BAE Will not ignite gas when turned on.
are you saying that when you set it to bake the oven doesn't heat or are you talking about the top burners?if it's the oven you have a bad ignitor, the oven flame should lite in under 40 seconds to a minute,if it doesn't it's the ignitor,part number 12400035 and it's around 80 bucks.unplug it or kill the braker,take out the racks,remove the bottom panel or oven floor,take off the wing nut and remove the metal cover and you'll see the burner tube and the ignitor,,with a wet paper towel wet the screw threds on the two screws with water so they don't strip out and then remove the two screws holding the ignitor on,trust me it works.if you have to, unplug the ignitor or if it's not the original ignitor cut the two wires at the end of the old ignitor and connect the new ignitor with the ceramic wire caps and remove the burner tube if it's hard to get at the ignitor screws.put it back together and the ignitor should lite the flame in less than a minute.let me know how you make out
Aug 22, 2010 | Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Hole in Bake Tube Kenmore oven....
heres the apart nuber forthe burner bar, the unfortunate thing for you is that the new burner bar comes with the ignitor already attached ,no worries hold on to either the one becauseit will go bad again. but no real trick to it 1 or 2 screws holds in place no gaskets or seals WB16K10035
Jan 20, 2009 | Ovens
Ovens Logo
128 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
