Question about Maytag Performa PAV2200
Belt stops running and clicky noises
My washer makes a clicky noise in the spin cycle and sometimes in the wash cycle. The belt also seizes up and just make a errrr noise and won't spin or agitate. The belt broke and we replaced it, but it is still making the noise and seizing. We thought something was in the drain discharge, but nothing. Can anybody help?
  • 183 Answers
If this is top loader the gearbox is faulty. Regards Advisor
Posted on Aug 23, 2007
SOURCE:
Washer won't spin and makes noise on spin cycle
Sounds as if it just a broken belt. Take the back off and find where the belt is located to see if broken. Depending on the washer they can be easy to fix
Jan 05, 2013 | Washing Machines
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Motor will not spin both ways
Starts fine then stalls, I would check the belt,gear case and also for a seized pump bearing. Pull the machine out and remove the access panel with a 5/16 socket and put it into spin, try to watch as you start the cycle. Then if you don't see any problems tilt the machine back and examine the belt for wear, glazing, cracks and rotate the belt to find any frozen items, gear case and pump.
Oct 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
No spin cycle
Sounds like a pump problem. If the tub is full of water, it likely won't spin...it's just too much for the motor. The pump is supposed to do it's job first by pumping out all of the water so the motor can spin the tub. I bet the noise you hear is the belt trying to run in a seized v-belt pulley.
Change the pump...bet that does the trick.
Jan 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
