As of the end of February my phone will not sync. I plug it in and the computer makes the noise that it is connected but the phone doesn't seem to acknowledge the computer. I have uninstalled the software and reinstalled it and it still didn't work.
I had the same problem go to settings connections and usb to pc and make sure you dont have the (enable advanced network functionality) box checked this solved my problem.
Have u check to seen if its not being use as a hard drive. Try this go to the start menu go to settings down at the bottom you should have 3 tabs 1.personal 2.system 3.connections. Click on connections then click on the icon that says usb to pc make sure that its in active sync. Your problem should be solved.
I have the same problem... it seems to happen every 30 days or so.
