Sanyo 32 inch blinks off
Sanyo blinks off and on no pic no sound
    Top Expert:
  • Televison & ... Master
  • 76,099 Answers
How many times do this standby light blinks at one time switch ON. Count it. These are fault indications, called blinking codes. From these number of blinks, you can get an idea about the faulty circuit section inside the TV. If you wish to get more details about these blinking codes, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. Blinking codes detail to many brand TVs are given in detail.
Posted on Jun 25, 2013
    New Friend:
  • 22 Answers
PARA DETERMINAR CUAL ES EL DEFECTO, SE DEBE OBSERVAR BIEN DESDE EL MOMENTO EN QUE SE LE DA ENCENDER AL TV., CUANTOS SEGUNDOS PASAN HASTA QUE COMIENZA A DAR LOS BLINKS., Y ESO SE DEBE ME IMAGINO A QUE LAS LAMPARAS NO ENCIENDE., Y EL INMEDIATAMENTE SE PROTEGE Y SE MANDA APAGAR DANDO EL CODIGO EN BLINKS DE FALLA EN LA FUENTE DE PODER.., POR TANTO LE RECOMIENDO QUE OBSERVE LA PANTALLA DESDE EL INSTANTE QUE UD., LO ENCIENDE LO PRIMERO QUE HACE ES ENCENDER LAS LAMPARAS Y DESPUES SALE LA IMAGEN., SINO SE OBSERVA EL ENCENDIDO DE LAMPARAS, EL DEFECTO ESTA EN EL CIRCUITO INVERTER.
Posted on Mar 27, 2014
2 Suggested Answers
SOURCE:
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
The picture on my new sanyo 32" tv shrank. there is a 4 inch black space on either side of the picture
This is normal when you play older 4:3 pictures on a 16:9 TV, which all new TV's are today. If it occurs on all pictures, then you have changed something in the setup. Look for a setting for aspect ratio, and try changing it to 16:9
Aug 29, 2018 | Sanyo Televison & Video
My 42 inch Sanyo no pic but win you shine light you can see the pic but no sound could that be the backlight
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Nov 03, 2015 | Sanyo Televison & Video
My sanyo 32 inch flat screen TV has sound but no picture is it time to get rid of it
It depends upon your electronics ability. In 90% of cases, get rid of it as it's not worth repairing.
Mar 22, 2015 | Sanyo Televison & Video
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo Vizon T.V. No sound, no pic
No,this is the internal hard ware power supply problem
Jun 01, 2009 | Sanyo DP32746 32 in. LCD Television
32 inch tv, 32mf231d/37 light blinking
There two caps on the power supply that the tops will swell up. Change them both and that should get you going.
Sep 05, 2008 | Philips Magnavox 27MS343S 27" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
