Question about Canon LaserClass 2060 Fax
Confirmation Report Is it possible to set it up to receive a confirmation of sent faxes individually rather than the report that appears periodically?
  • 328 Answers
Re: Confirmation Report
Do you have a manual? It can be set for individual. Go to Canon and download manual.
Posted on Aug 23, 2007
0 characters
3 Points
How to get a fax confirmation on a canon faxphone L190
There should be a button on the front of the fax 'Reports'. Push that. Then go to 'Report settings'. Select that option. For confirmation reports that a fax was sent 'TX Result Report'. Turn this 'On'. You should be set. We just figured this out on our faxphone.
Nov 29, 2012 | Canon Fax Machines
How do you get a printed confirmation of a sent fax? Cannot find the answer in the manual. Thanks
In setting mode , Go to report setting and inside that go to Tx report or transmission report ,or sent report or like the same (depends on brand and model).then set it on and then every time you sent a fax, a report will be print to show confirmation or any error. pls try to clear you model no. and brand name whenever you would like to ask question.
Jan 07, 2011 | Canon Fax Machines
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
Confirmation report lists incorrect no of pages sent
You may have a sticking actuator arm under the feeder; or in the feeder depending on make and model.
This would allow the pages to be sent but not counted correctly.... I assume that the count on the confirmation report is always LESS than the pages actually sent, at the time you have the problem.
Mar 18, 2010 | Fax Machines
Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Sep 09, 2009 | Canon Fax Machines
WE have a canon laser class 700 series fax machine. Is there a way to get an automatic confirmation to print after something has been successfully sent?
Press adisional funcktion button,select report settings,select TX report set it to "output on"
Then you will be able to receive the report for every fax you sent.
Dec 18, 2008 | Fax Machines
Confirmation reports
Mar 29, 2008 | Canon FAX-L800 Plain Paper Laser
Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Feb 20, 2008 | Canon FAXPHONE L80 Laser
Canon LaserClass 2060 Fax Logo
168 people viewed this question
Top Canon Fax Machines Experts
old marine
old marine
john archer
Are you a Canon Fax Machine Expert? Answer questions, earn points and help others
