Question about Philips DVP642 DVD Player
Standby light blinking
My player will not turn on or open. Have tried unplugging it, pulling out all cables...nothing is working. The standby lights blinks on and off then stops for a while until I try to turn it on or open it again.
  • 15 more comments
  • sperdue Dec 13, 2007
    Same problem but the solutions dosnt seem to apply as the 'drum' is not buldging or leaking.
  • paulchicago Jan 03, 2008
    I have been unable to find the capacitor specified - a 1000u >=16V, or a 10 V or 12 V for that matter. Radio Shack didn't have it, neither did Newark. Any suggestions? I have the unit all taken apart, and I told my wife I had if all figured out, so this is serious now.
    Paul Kamp, Chicago [email protected]
  • Midwest Jack Jan 04, 2008
    I replaced the capacitor with Radio Shack 272-1032 (1000mf, 35 volts) capacitor and solved the problem. Thanks for the tip!
  • jephthah Mar 09, 2008
    i had the exact same problem, and replacing the C319 (1000uF cap) fixed it.
    to repeat earlier comments, don't look for it to be necessarily burst or oozing. it could just be a slight bulge.
    a
    1000uF electrolytic capacitor is *extremely* common component. you can get them anywhere.
    make
    sure it's at least rated for 16V. any more than 50V will probably not
    fit into the footprint on the board, but you could conveivably force a
    250V rated cap if you had to.
    the key is 1000uF, and at least
    16V.. that's it.... they're common as field mice. if Radio Shack is out of stock, any electronics supply store will have them. you could probably just open up some old junk electronic device and cannabalize a similar part if you were desperate...
    the root cause of the problem is that Phillips put 10V Capacitors on a 12V Power Supply. so
    of course its going to eventually fail, due it to being overvoltaged.
    the longer you leave the device on at a time, the sooner it will fail.
    so if you replace it with another 10V cap, it
    will eventually fail again, in about the same amount of time that it
    took it to fail the first time.
    the real question is, why is Phillips installing 10V caps in a power
    supply that calls for 16V? incompetence? negligence? what? i almost
    wonder if they did it on purpose so the device would fail shortly after
    warranty and require people to buy another.
  • Anonymous Mar 13, 2008
    same problem as listed prior. c316 capacitor was blown. Replaced it and all was good. Thanks for the tip.
  • Anonymous Mar 19, 2008
    Same here - it WAS the C316 capacitor, was blown (barely bulging) - replaced it with 1000 uF, 35 V from Radioshack ($1.59) - and it works! Thanks, shardian, and everyone else!
  • Ivhigo Apr 01, 2008
    The same thing as was happening to others happened to our dvd player. RED LIGHT OF DEATH! I have never opened nor fiddled with electronics before but if you want to solve the problem of the red light of death just follow the simple directions as posted by Shardian Solution #3. In just an hour, which included me going to Radio Shack I was able to fix the problem. If you know how to follow directions it should be an easy fix. Thanks for you help. :)
  • Anonymous Apr 25, 2008
    standby light blinking, the disc tray wont open, seems partialy dead.
  • Anonymous May 11, 2008
    Same problem here. I'm thinking I won't be purchasing any Philips products after this. If they are building electronics with a pretty obvious flaw and won't stand behind them...they don't deserve my money.
  • hltr May 24, 2008
    Perfect solution on the Radio Shack replacement. $1.71 and 20 minutes of my time.
  • milligold Jun 14, 2008
    Thank you!  I can't believe I just opened up a DVD player and fixed it with a soldering iron.  My husband thinks I'm amazing!  The capacitor (35V) was a bit bigger than the original, but it works just fine.  I have two of these DVD players, so I won't be upset when the other one gives me that "blinking light" lip.
    Carole
  • Anonymous Jun 16, 2008
    Shardian rocks! Solution #3 is winner. I found the recommended capacitor on a 15 year old modem I had in my junk parts drawer and soldered it in. Now my wife is impressed and she will probably leave me alone about my very respectable junk drawer. Thanks for the post.
  • Anonymous Jun 24, 2008
    standby light blinking problem
  • ashlyank Jun 24, 2008
  • Anonymous Jul 05, 2008
    it worked. thanks
  • Anonymous Oct 25, 2008
    standby light blinking problem, no power AND I have a DVD stuck in the machine!
  • mark_air May 11, 2010
    Shardian solution #3 was extremely helpful and the step by step directions made if effortless.
    I already had a soldering "pen" so I just had to purchase Radion Shack part# 272-1032. They had it online and in-store. HOWEVER, after 20 minutes I had the new one installed ($1.59) and still nothing.
    I never had the blinking red light to start with. It just didn't power up at all. I unplugged the wire connecting the two circuit boards and plugged the DVD player back in. Now there was a blinking red power light, but still no power. I tried holding the power button, unplugging the wires, checking the fuse, but nothing else worked. I plugged the wire cluster bridging the two circuit boards together and the the power light stopped blinking. Now I'm thoroughly confused.
    I originally never saw any "bulging" capacitors or "oozing" capacitors. I do see (tiny) capacitor #274 on the other board with a small amount of white residue and the largest capacitor #304 has a tan/cream colored "ooze" under it but it looks like it's glue holding it down against the board.
    ANY IDEAS??
    My $40 DVD player is just inches away from the trash. A couple years ago when my Philips DVP642 died I purchased an Onkyo DVD player to match my reciever...flawless.
    Problem Solver:
  • 5 Answers
Here is the solution. This is a common problem with this player. Common DVP 642 problem (only problem with a great player): They die, and you have a blinking red power button. This is actually surprisingly easy to fix. It's really easier than I make it look, but I'm just being really clear in case anyone reading this has never seen a soldering iron before. Here are the steps I did (and note that, if you're still under warranty, this will void your warranty). The decision to try this is up to your own discretion and may be a last ditch effort before throwing the player away. Short version: Check the board to see if capacitor C316 is bulging. If so, get a 1000u capacitor >=16V and replace it. Long version: 1. Unplug everything 2. Unscrew the side and rear screws to remove the top cover. 3. On the board where the power cable goes in, look for a capacitor (looks like a little drum with a '+' on the top) that is bulging upward either a little or a lot. It may be leaking some brown fluid as well. 4. I'm betting that the writing on the board at this location says 'C316'. If you google 'dvp642' and 'c316', you'll get hundreds of hits... 5. If that's the case, you'll need to find a capacitor and a soldering iron. Visit radio shack or similar electronics place and buy an elecrolytic capacitor that says 1000u (the 'u' is actually a lower case greek 'mu') with a voltage greater than or equal to 16v (this is not calculated: it's simply what others have reported success with. I couldn't find one and used a 35V one instead). You should be able to find one that looks somewhat similar to the damaged one (it might be a little bigger or smaller, but you'll want the same basic shape). This should cost less than $2. 6. Borrow or buy a cheap soldering iron and some solder. I borrowed one from a friend at work...this is NOT my area of expertise, so don't worry about the difficulty! 7. Now the tricky part: back on your DVD player, you need to get that board out. Unplug the two cables connecting to the board we're working on, unscrew the screws holding it down, and, using some pliers, hold down the wings of the little plastic piece that is still holding the board down and slide the board up. I flipped this around to get at the bottom while leaving the power cord in place. 8. Heat up the soldering iron. Locate the spot on the bottom of the board where the C316 capacitor is attached. Remove your new capacitor from the package. There should be one shorter leg which is the negative side. It will likely be marked this way as well. 9. One side of the capacitor should have a ' -' on it. Note which side this is. You may not be able to see it until it is removed, so be aware of needing to know this as you remove it. 10. After it is warm enough to melt solder, lay the soldering iron across the joints you identified as belonging to C316. Tug gently on C316 as you do this and it should soon come free. This is a little tricky to hold the iron, the board, and the capacitor all at once, so please don't burn yourself! Again, note which side is negative and which hole it came from. This is the negative hole, and the other is positive. There will likely be some solder left over around each hole. Just try not to let it run between the two holes or you will short out the connection. 11. Grab your new capacitor and line up the longer leg with the positive hole. Lay the soldering iron against that hole on the other side and push the leg through. Line up the negative leg/hole and repeat. Lay the iron across both to heat up enough to push the capacitor legs through and the capacitor down to the board. 12. Check the connections for each leg. There should be a small mound of solder joining each leg to the metal of the board, but not running to any other point of the board. If it's run to some other points, you'll need to do some searching to see how to clean up it up a little bit as I'm not an expert at this. If you need a little more solder, lay the iron across the joint for a few seconds, then feed your solder into the hot spot until a small amount flows over the joint. Remove the iron, wait a moment, then remove the solder. Look at the other solder joints on the board for a rough idea of how it should look. 13. Use some wire cutters to trim the legs down to the solder. 14. Pop the board back over the plastic piece and reconnect the cables. 15. At this point, you're on your own. Personally, I made sure I wasn't touching any metal and plugged it in. Since I didn't blow any fuses and the player seemed to work, I unplugged it, reassembled it, and went to watch a movie.
Posted on Aug 29, 2007
Answers #3 and #5 were right on the money! It took me 20 minutes and $1.59 to fix a DVD player my neighbor was throwing out- the thing looks brand new!
Thanks!
Posted on Oct 28, 2008
This is an awesome site and great solution. Fixed her up in jiffy and my kids now think I am a GENIUS! Thanks Sharidan
Posted on Jul 04, 2008
I wanted to say thanks so much for posting the solution/fix for the Philips 642. Only took a few minutes to crack open the box and find exactly what you were talking about. Removed the old capacitor, made a trip to Radio Shack for a replacement, returned home and soldered it in. Powered right up and working fine. Very much appreciated!
Posted on Jun 23, 2008
Just got the nod, my little fiance, showed me this article, went to RS, came back got the soldering iron out, opened it up, meesaged me back and she did it. SHE DID IT. Never once have I seen her open ANY electronic; yet, she did it and me at work posting this comment of how she did it. I may have to show her how to use the dremmel now.
Posted on Apr 01, 2008
Worked great, took all of 15 minutes to fix, after running down the part.
Posted on Mar 25, 2008
  • 4 Answers
Hello, people:
a 1000uF electrolytic capacitor is *extremely* common component. make sure it's at least rated for 16V. any more than 50V will probably not fit into the footprint on the board, but you could conveivably force a 250V rated cap if you had to.
the key is 1000uF, and at least 16V.. that's it.... they're common as field mice. if Radio Shack doesnt have one, any electronics supply store will.
and ESR is not the issue. anyone who says it is, doesnt know what they're talking about, and is just parroting the same misinformation. we're talking about a power supply circuit, not a high speed microcontroller.
the root cause of the problem is that Phillips put 10V Capacitors on a 12V Power Supply. so of course its going to eventually fail, due it to being overvoltaged. the longer you leave the device on at a time, the sooner it will fail.
so if you replace it with another 10V cap, it will eventually fail again, in about the same amount of time that it took it to fail the first time.
the real question is, why is Phillips installing 10V caps in a power supply that calls for 16V? incompetence? negligence? what? i almost wonder if they did it on purpose so the device would fail shortly after warranty and require people to buy another.
Posted on Mar 09, 2008
Not a solution, just a comment and maybe a tip. I second PanicBoy when he noted the C306 cap doesn't have to look a gods-awful mess to have gone South. For anyone having trouble finding it, in my DVP642/37 it was identical in size, shape, colour(s) and orientation to the caps marked L303 and C318. On C316, look for a tiny bit of bulging and look again @ the other two, whose scored tops should be flat as a mousepad by comparison. BZT
Posted on Jan 21, 2008
I bought 2 of these players a couple of years ago and last month they both fizzled out and gave me the blinking light.  One of them had my friends dvd trapped inside.  I was pretty bummed.  I was about to smash one of them open today to get my friends dvd out but decided to do a quick search on any possible fixes.  Well, two hours later and a trip to Radio Shack and the darn things are working.
I have NEVER soldered anything in my life and if I can fix this you can too.
Thanks for the awesome instructions!
Instead of replacing the players I spent 15 bucks at Radio Shack.  Here's what I bought:
1.  Cheapest solder gun ($6.99) 2.  Solder ($3.29) 3.  272-1032 Electrolytic Capacitor x 2 ($1.59 each) 4.  Desoldering bulb ($4.49)  ((The salesman talked me into this and I didn't think I needed it, turns out I didn't and I'm returning it))
I couldn't be happier right now.
I will not, however, recommend a Phillips player to anyone after all of this.
That's my 2 cents.
Posted on Jan 10, 2008
Thank you SO MUCH for this. I found the part on an old 486 I had and I'm up and running again. Long live the internet and great people like yourself.
Just want say I followed Shardian's advice, and the hardest part was finding the part. It was easy to remove and work on the board and it took me about 20 minutes from the time I plugged in my cheap soldering iron until it was working fine. I do have a solder "sucker" (manual handheld one) and it helped a lot with removing the old part.
I found a 1000u 16v cap at www,allelectronics.com - it cost less than $5 including shipping - arrived in three days.
The player works like new. Thanks everybody.
I've had this DVD for about a yr and just got this problem last night. At first it would not turn on then when I pressed the standby button and the open/close button together it worked and the dvd slot opened. However, tonight when I tried to turn it back on I found the same blinking light everyone else has posted and does not power on.
I just called Phillips (surprised that their tech support was open this time on a Saturday night) and they had me unplug the player for 20 seconds and press the standby button and plug into the wall at the same time and hold for 10 seconds. That did not work either. They suggested that I send the player to an authorized dealer to remove the dvd in there now and would replace my broken one for $37. I registered this product when I purchased it but the warranty is only valid for 90 days. I asked if I the replacement would be the same model and they said yes. I decided against getting it in case the replacement pulls the same crap in a year.
Since I am not tech savvy I am probably going to toss this one, do some research and buy another one. I am just disappointed because this is the 2nd dvd player that broke on me in the past 2 yrs.
Just wanted to post that Phillips is of no help when you call, unless it's been close to the purchase date. Also, the guy sounded surprised when I told him I was on the internet and many people have reported the same problem.
Posted on Jan 06, 2008
Radio shack 272-1032 Electrolytic Capacitor did the trick! Thanks for the help!
Posted on Jan 04, 2008
Holy crap on crap toast with crap sprinkles!
It worked!  I rarely fiddle around with guts, but this sounded simple and cheap, plus the big loss was a fifty dollar DVD player that was bricked already.  How could I make it worse?
So I took the cover off and sure enough there it was, C316, all bulged and oozing.  I went down to the electronic thingamajig surplus shop, grabbed an iron, some solder, and the 1000MFD/16V/105C capacitor and went to work.
It was not easy getting the burnt one out at all.  I ended up going medeival on it with a Dremel.  But I got two half-meh joints and the leads weren't moving when I wiggled the capacitor, so I figured it was a solid enough kludge job.  I ain't no artist with the solder.
I plugged it in, said a quick how-ya-been, hit Eject, and my trapped Netflix rental came out.  I'm watching it now.
Shardian, you rock hardcore with yer bad self.  Thank you so much.
Posted on Jan 02, 2008
  • panicBoy Jan 03, 2008
    Anyone who needs this particular part and can't find it, I have a surplus parts shop down the street, I'd be glad to send one along.  They're two bucks, and I'll ship for another two.  You can Pal me the four bucks at [email protected] ... be specific, and put "C316 capacitor" in the comment box.  If you want it shipped Priority, put that in the comment box and make it another two bucks.
  • panicBoy Jan 09, 2008
    And don't look for the capacitor to be all tumor-like and burnt-looking.  The signs of failure can be very subtle.  Look for even a gentle dome-ing of the scored metal top, sort of like a bulging can of soup.  There may be a touch of brown ooze, or there may not.  Take a look at the other capacitors for comparison, but dollars to donuts, that's the one.  What have you got to lose?
Could be the controller(chips) , power supply or simlply shorted wirings if you'ved mess with the internal parts.
Posted on Aug 24, 2007
After a lot of researching and failed tech support calls, i unplugged the dvd player for about 30 seconds, plugged it back in, held the standby button for about ten seconds and let go. after a few seconds of what i thought was another failure, it said loading and finally opened when i pressed the eject button. its working fine now so i think you should try this. it may take a few tries for it to work for you but hopefully it will eventually work.
Posted on May 18, 2008
SOURCE:
I havent used it for awhile but noticed one day that the standby light was blinking tried to turn it on and nothing opened it up fuses were good can anyone help!
Try unplugging it for a couple of minutes then try again might just need to be reset.
Posting the make and model would help.
Nov 19, 2009 | Audio Players & Recorders
Goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Sep 11, 2009 | Denon AVR-1905 Receiver
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Philips DVP642 DVD Player Logo
2,063 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
